Phone mount and Cup holder
Yes, I understand that you have to manually open the cup holder to hold larger cups. Here are pics of two insulated mugs that I have (yes, the garage is a mess!): the silver one (no name brand) fits somewhat and I can actually use it if I'm careful, but it does not insulate as well as the Contigo which is my preferred cup but it doesn't fit at all. I'll have to try the McDonalds cups, but I know that 7-11 cups do not work. Just too loose.
I just had a Subway large cup in there today - no issues. This cup is larger than the McD's and holds more (I had the McD's from yesterday and it fit inside the Subway one, but this didn't work the other way around).
My wife's cup is this one, I believe: https://smile.amazon.com/gp/product/B085RD64Q3/
Hmm... maybe the 987.1 ones are different (mine is a 987.2). In mine, you can see the cup sits lower and the clip section opens up and clicks to various sizes... so I'm guessing I may not have the "too loose" situation you mention? i don't go to 7-11 *don't even know if there is one around me!)... so I can't do a direct test for you.
The one your wife has looks like it will fit better. Based on the listing it has roughly the same base diameter as my silver mug, but doesn't appear to flare out as quickly so maybe that makes it seat better. I just ordered this one based on price and reviews - one of the answered questions says the base diameter is 2.5" (slightly smaller than my silver mug) and the body looks pretty much straight with little flaring.
I actually use the left most 987 cupholder as my phone mount, as is. My iphone slides in, then i close the cup holder claws tight around the phone. It's not perfect (phone does face me directly, front claw is in the way a bit), but since it's not my daily driver it's actually quite a simple soln when I do need to use the phone for navigation or music. (Of course, this doesn't solve the holding the cup problem).
No, I doubt the 987.2 design is different. There's room for the cups to sit deeper but they are just too large in diameter. The silver one's base slips through but it flares out so it only goes in about half way, and the flared design makes it prone to rocking since the base doesn't seat far enough.
The one your wife has looks like it will fit better. Based on the listing it has roughly the same base diameter as my silver mug, but doesn't appear to flare out as quickly so maybe that makes it seat better. I just ordered this one based on price and reviews - one of the answered questions says the base diameter is 2.5" (slightly smaller than my silver mug) and the body looks pretty much straight with little flaring. https://www.amazon.com/dp/B08CX6V4NQ...hk_typ_imgToDp
As you noted, it's basically a straight taper from the bottom up...
Woah, my Contigo measures 2.75" at the base and it will not fit in my cupholder! Maybe the 987.2 is in fact larger. I'll report back when I get the new one that I ordered.
My new cup came in today and this one fits much better. It measures 2-5/8" diameter at the base. The only question is can you lock the cup holder position? While the cup fits great, it is very easy to expand the holder one or two clicks more to the maximum width. If you hit a bump or something it could happen by accident and allow the cup to flop over.
Looks good!
My 987.2 holder does click, and it doesn't lock into place (if it did, you couldn't put it back into the closed position). As for it opening by itself, I don't believe that would happen... it doesn't seem that loose on my car. I haven't been extra crazy when driving with a large cup, but it never seemed to be "close" to moving.
One more comment, if you don't close the cupholder door, the arm will swing around. Closing the door keeps this from happening. With that in mind, clearly I drove hard enough to have that happen, and yet the clicker didn't move.
Update: So I ordered and received an "ultimate cup holder" today. I'm not sure I got the right one. I ordered it for my Cayman, but what showed up is generic, friction fit thing. I have emailed the company asking to get it swapped out the the correct one for my Cayman, with directions, and hardware to attach it.
Anyone else have this experience?
The following 2 users liked this post by zuch:
Miggytosh (02-01-2022),
tomhartzell (02-01-2022)
Here's a drink holder "tech tip" from the SnapOn Tools people:LIF
DUCT TAPE DRINK HOLDER
Keep a roll of duct tape on the center floorboard in your vehicle. It works great as a cup holder and it's just sticky enough to stay put. When you need the roll, you'll know right where to find it.
Snakebit (02-07-2022)
Thanks Tom - been looking for one for my 987.2 S - AND for my 914 and my 931.......if it will also fit in them as well as the Cayman, I'll order 2 more........
GN
GN
I used one of the Ultimate Cupholders in my Cayman before selling it; it did a great job. (No affiliation with the company)
https://www.ultimatecupholders.com/index.html
