Working on a 987 3.2 with cooling fans running constantly. When you start the car they're off, and they cut in after 20 seconds or so and keep running. Also temp gauge not working.
Have changed the fan control module, and that made no difference. Any suggestions please!
We've tried the engine temperature sensor and it made no difference.
The fact that the fans don't come on until 30 seconds or so after startup would suggest that it's not a faulty solenoid either. I would suggest if it were the fans would run immediately. Would you agree?
If so I'm stumped as to what to try next.
It wouldn't be the engine coolant thermostat either. If it was stuck shut it would take time for the fans to work, and if stuck open it would take even longer.
Still getting nowhere with this guys but thanks for all your efforts. We're going to have to bite the bullet and book the car in to a Porsche specialist and hope it's not a fortune.
I am having this exact same problem and cannot figure our how to fix it either. I would be really grateful to hear what you did in the end please!
