Parking for Winter...
With living in the dark dank North, I have the looming winter season on the horizon. I'm not a fan of winter, and have a large disdain for snow. This year is going to be tougher, as I'm going to be forced to look at my dream car....under a cover....in my garage....for a LOOOOONG time....while not getting to drive it (a whole new level of self-torture!!)..
But anyway - enough of my rant.. I'm looking for advice and experience from other Cayman owners, on how to correctly store a car for the long sleep. What are some of the things you do to keep your car perfect, and healthy, while it sits? I'm sure I need to keep my battery tender hooked up. But how long? Do I just always have it plugged in? I'm planning an oil change soon - before it's parked. Is there anything else I should do - mechanical wise - for this long period?
I have no plans of starting the car, and letting it sit and idle, at intermittent periods - as I've understood this is not good for the engines. Even the hardy 2.7l version.
I'm trying to drive it, as long as possible. The weather has been (surprisingly) great, lately! But we're likely to start seeing snow, within the next few weeks. And it typically 'sticks' by November. So if I make it into early November, before she goes under the wraps, I'll be very fortunate! But it'll be a VERY long wait for April/May....when the crappy snow is hopefully gone.. So that's 6 to 7 months, on a good year!! Sometimes it's longer....uhhgggg!!!
Here's one thread that I've found on the topic, https://rennlist.com/forums/987-foru...r-storage.html
My storage is pretty simple, fill the tank, air the tires up to 45psi, put on the charger and the cover and call it a day. I've stored my car the past 3 winters and have had no issues, other than last year where my bad battery totally failed over the course of the winter.
Sometimes I think of getting some Nokian Hakas in the stock 17" size and driving the car in the winter. It would be a riot, but for every good winter driving day (fresh snow!) there are 20 when the roads are a salty, mushy, disaster and the car would end up sitting anyways.
Blasphemy, I'm sure... but I plan to run mine a few times at least... but I'm also further south (Connecticut, USA) than you... but I've seen others post photos of their cars in the snow, too!
I think of it this way, if I daily drove my Cayman in the winter here it would last for about another 10 years. If I keep it for summer driving it will last the rest of my life and I can pass it down to my son when I'm dead assuming the Porsche e-fuel thing works out. I'm going with the latter, and besides, my Golf R is still pretty darn fun to drive in the winter.
Hello KrisA.. Been a while since I've graced the quiet Province of Saskatchewan. Still lots of (distant) family, out that way..
I'm pretty confident that I won't have to worry about rodents. The car will be in my heated attached garage. We've lived here for over 4 years now (newer house, and area), and haven't seen any evidence of such critters. I'm out in my garage quite often - doing all sorts of projects, and whatnot. And my indoor cats do pop out with me, once in a while. They'd definitely alert me to such things.
Driving in the winter.. hrmm.... It is something I long considered. Even before getting my car. At first, it was a way to justify such a car purchase, living in a place where sports cars typically only have about 4 to 5 months of driving season. As well, these cars were designed to be driven - no matter the conditions! Put on winter tires....and away you go.. A few friends thought it would be utter sacrilege, to hoon around in such a car...in the winters we get. And I partially agreed. But.... I really considered it! However, the problem (for me) is that the car I ended up with is in such 'cherry' condition!! And as a couple people above mentioned, the crap that is put into the snow removal, is really not 'healthy' for such a car. They put a LOT of sand and pea gravel on the roads around here (not sure how much salt gets used anymore - I think that's no longer in practice, in these parts). So the sand and gravel makes our roads very rutty, and very messy! That kind of abuse on the underside, and paint....not sure I'd want that.
The tire inflation sounds like a good plan. But I was planning to take it a step further. I'm a bit of a wood craftsman - and have a bunch of scrap wood around (always). I was thinking about building some tire cradles. Nothing fancy. Just something with a matching curve - to help keep the roundness.
Seems like the amount of fuel left in the tank is a bit of a debate. And adding some stabilizer. I'll have to do some more research there..
Love driving a P-car every day.
But to each his own.
- Clean it inside and out. There's nothing like the first spring day for a drive and the car is clean!
- Fresh oil service. So when spring arrives I'm ready to go.
- Over inflate the tires a bit to prevent flat spotting. Once the tires warm up flat spotting goes away anyway.
- Hook up the battery tender.
- Lock it up so I goes into hibernation mode.
- Give one final look and go have a drink
I would add to Matt's post above:
1. Put a cover over the car to protect it from bumps/scratches
2. Some people shove steel wool up the tail pipe to prevent mouse invasions
3. You can throw some desiccant packs in the interior, the trunk and the frunk.
I liked having a checklist for both putting the car to sleep and for bringing it out of sleep (for example, you don't want to forget about the steel wool in the spring).
