987.2 front LED bar/strip bulb info
Hi all,
I posted the same topic in planet 9 but didnt response from there so i thought i could try here as well.
I have bi-xenons on mine and recently swapped out for some 6000k D2S bulbs in my headlights. However, this has now increase the contrast between the LED bar/strip when the headlights are on... anyone knows if that bar/strip is serviceable, i.e change out the bulbs? Looking to change out for more cooler temp bulbs...
Thanks in advance peeps !
Received 1,150 Likes
I suspect that you won't receive any posts from people who've done this - since no one ever posted about doing it here or on Planet-9. I think you'll be the pioneer. Pull out one of the lights and see if it can be disassembled. Most of the Porsche LED lights can't be since there is no anticipation of ever changing a bulb in one. Bet they're glued up as a solid lump.
