Price for a 987.2 Cayman?
#62
I predict the used car market will cool off once the majority of the workforce is busy again and people start focusing more on new cars. But that'll be Q4 of this year at the earliest, I reckon.
#63
I wanted to give a quick update: I bought the "other car" that was on my list, a 2017 BMW M240i. I got a very good deal on it. I know what I'm giving up by going this route, but I actually replaced my daily with this car. I want to see what the 987.2 market does, and take my time for the exact specs I want.
This 987.2 S will be very interesting to watch. Wrong color combo for me, and the DME is a little scary. Admittedly I have much to learn about engine hours since scary numbers.
I'll still hang around here because of the knowledge this board exudes, and someday there WILL be a Cayman next to the Bimmer.
#64
Congrats on the M240i!
#65
Seems like M240i is a great option as a driver's car in this price range, congrats
I agree, there might be some sort of story since the number of cycles in range 3 is lower* than 4-6 but personally wouldn't bother.
#66
Yeah. That car gets a "nope" from me. I'm guessing it has seen seen significant track use as well. The lack of proper .2 wheels that it came with (and apparently buckets) is a turn off. And the interior looks like they just sprayed tire shine all over everything. I would guess it goes for low 30's, but the DME report seems like it will be a total deal breaker for most buyers. No point in paying more for the .2 engine when its potentially damaged anyway.
#67
#68
Yeah that's possible as well. My guess was some horrible interior dressing product judging by the slimy look of the radio.
deilenberger (04-02-2021)
#69
Only guessing as you don't see any black scuff marks anymore. Checking the pictures again, it looks like they took apart all the interior pieces they could take out to repaint it with the shiny paint - door handle and mirror trims, center console, ignition key surroundings?, pieces around the gauge cluster, the pieces that surround the engine cover, even the chrono clock shroud. Every other interior piece not painted seems to have been scuffed up, even the metal pieces between the seats.. and what's up with the red plastic piece inside the seat belt thing worn out? I didn't even notice it was supposed to have the sport bucket seats, aren't those like 5k+ option? All this with misaligned exhaust and DME report, I wouldn't touch this one but will follow to see how much it ends up going for. Not a lot of 987.2 come up on BAT.
sectachrome (04-02-2021)
#70
Not to say others are right or wrong, but I don't think the DME is necessarily a deal-breaker if it wasn't recent. For example, the car I just got had revs in 4, 5, and 6... specifically 51 in range 6. However, these were about 800 hours ago, which calculates to about 20+k miles ago. People here and even the well-regarded shop I went to for the PPI agreed that since it was so long ago, it wasn't something to be concerned with. I agreed, and purchased the car. The shop and I agree the car runs GREAT... they didn't even expect to see any codes or DME issues, that's how nicely it runs (they found a few codes leftover from a previous repair, which they didn't expect - misfires likely due to a crank position sensor that was replaced some time ago).
Of course, this is my opinion... and I put my money where my mouth is, but many others agreed with me on this... so, my advice is not to worry about the DME by itself... look at the timing of the events and the rest of the car... again, this is just IMO.
#71
Schwinn (04-02-2021)
#72
I agree it's not necessarily a deal breaker but considering this one was only about 120 engine hrs ago, maybe a compression test or leak down test(?) should be done to make sure no damage was done? Not sure which would be definitive or even telling on Porsches but a low compression on a S2000 would at minimum require a rebuild. You would also be subject to more scrutinization when you try to sell it down the road. Even though the car's meant for driving, it should all still be factored in to the purchase cost of the car versus one you wouldn't have to worry about any of it.
#73
Thanks for the well wishes with the Bimmer
The 240i sure seems like a drivers car to me. I did my first short canyon run yesterday and while the acceleration is no surprise, the brakes were phenomenal. I didn’t push it too hard or long enough to know if they fade at temp, but it was very fun. The *** end of that car will push you out of a corner in a much different way than the P car I’ve driven. Having said that, the steering isn’t even close - not the same league, not the same planet.
The DME on the one I listed would scare me to the point of not bidding. If the oil analysis had mileage on it, then that’d be something at least. I’ll be watching for market data.
#74
No argument about the recentness of your event. I didn't see that reported above (maybe i didn't read back far enough, so that's on me). I agree, with a recent one like that, it's worth being concerned for sure. I was just trying to make the point that a bad DME doesn't, in-and-of-itself mean you should avoid the car. I agree in your case, this makes sense.
#75
Received 1,150 Likes
I really don't see that much to complain about on this car from the information given. There have been over-revs, but if it had been a money shift that's known right away when the engine explodes. Chances are good with more than 100 hours on it no damage was done. I'm guessing it will go for mid 30's or higher. Hot color, decent interior color, a desirable model with manual transmission (for some people.)
