P1096
My car has p1096 right now and stalls once it is at operating temp. I took my car in to the shop for a smoke test, they said it was the maf. So I replaced the maf with a new Bosch unit figuring the Bremi maf had failed. I tried cleaning the TB but no dice.
Any suggestions would be much appreciated!
Received 1,150 Likes
Hellow Happysunflower ![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Welcome to the 987/981 forum!
https://www.carobdcodes.com/porsche-...sensor-1.shtml <-- that's just what Google turned up
But that's just a guess since we have no idea what vehicle (year, model, engine) we're talking about. We kinda need that sort of info if you're expecting an intelligent answer.
Here is what AllDataDIY turns up:
Mass Air Flow Ahead of Throttle Valve Implausible (Too High)
P1096
Mass Air Flow Ahead Of Throttle Valve Implausible (too High)
Diagnostic conditions
Possible fault causes
Diagnosis of plausibility of MAF sensor signal
P1096
- Supply voltage 10 V ... 16 V
- Engine start
- No faults detected for throttle valve adjusting unit, ambient pressure sensor, intake temperature sensor, speed sender
- Hot-film mass air flow meter faulty (battered)
- DME control module faulty (ambient pressure sensor at fault detection threshold)
- Power supply voltage 10 V ... 16 V
- Engine start
- Air cleaner blocked
- Leakage between MAF sensor and throttle valve adjusting unit
- Throttle valve sluggish or heavily soiled
- MAF sensor faulty (battered)
- One or both cylinder banks remain jammed in small valve lift
- The measured value supplied by the MAF sensor is compared to a value from a map. This map is determined by engine speed, throttle valve position, ambient pressure and intake air temperature.
- The mass air flow upstream of the throttle valve is identified as implausible if the measured value deviates too greatly from the map.
- If the switching cups stick on a small stroke on one or both banks (e.g., oil duct blocked), the MAF sensor can also be detected as faulty. This is because the expected increase in the air-flow rate does not occur.
- The monitoring of electrical faults (open circuit, short circuit) takes place in a separate diagnosis.
