Cleaned your drains lately?
Why is cleaning the drains important? Because Porsche mounted expensive electronic modules right on the passenger compartment floor - where flooding will damage them, and likely the connectors from the wiring harness to them. Repairs in the multi-thousand dollar range are not uncommon. Due to it's nature - the soft-top of the Boxster makes this more common - and there are multiple drains involved specifically for the soft-top. But - the Cayman isn't immune. It shares the same drains in the cowl area that the Boxster has and they're equally susceptible to plugging up and causing flooding. It's particularly likey this time of year as the leaves start falling.
So below are two diagrams and two number-guides. You might want to print them out and toss the one that applies in your glovebox, or car documentation.
BOXSTER:
CAYMAN:
There are lots of techniques discussed in other posts about tools and techniques used. For the under-hood cowl drains - they're accessible by removing the beauty panel over the battery and the two cowl end panels. Cleaning the area of leaves is helpful, and many people find it helpful to simply remove the rubber one-way drains that Porsche uses in the cowl drain holes. The rubber drains tend to clog up with debris, especially leaves and whirligigs (oak tree seeds). Removing them gives a better chance of the debris passing through without clogging. A good cleaning of the area is helpful, and you don't have to remove the battery to clean this area.
The other drains - Boxster and Cayman are toward the rear of the car, and in the Boxster in the top compartment. There are more there than most people know of - some are rather subtle - a drain that runs right through the rubber trim the top seals to is seemingly unknown by most owners. Compressed air is good to clean these, provided you don't use too much pressure (which may blow the drains apart at a joint). The Boxster top drains are easier to see with the rear wheel-well liners removed. You can see the output and by pouring water into the drain from the top, confirm that they're open. There are two drains in the top compartment, visible if the top is partly opened (clamshell up and rear of top lifted). These go into the rubber membrane that lines this compartment and may have to be looked for. Once you find them - they're pretty obvious. Porsche sells a screen for these drains that keep it from clogging if something like a leaf land on top of it - before having the screen this was very likely to happen since the water going to and down the drain would carry debris and leaves right to the drain. The screen sticks up about 1/2" - and effectively stops that from happening.
A cleaning tool I've seen mentioned but I haven't tried (I might for my Cayenne drains - same problems) - is a trombone (or bore) brush:
You can find these easily, and probably even locally by just Googling it. Amazon of course has a bunch of them.
For the moment I'll sticky this thread - and hopefully, members will have some input for it. If we ever get a dedicated 987 DIY forum - it will be copied there.
I expect that using the smaller of the two brushes on 67" "hose pipe" should do the trick.
Last week, I discovered that my sister's 2017 TT was totaled after clogged drains led to massive electronics failures. I bought these brushes within minutes of hearing her story :-)
New (as of April) 987S owner here. Just got back from a month in Mexico and car was snow covered when we got home. When I got the snow off, there was fog on windshield and rear window. The carpet behind the seats (back wall, not floor) was wet, so I put it in service mode and checked the roof drains. There was a little water on each side puddled up and when I removed the small amount of debris there the water seemed to drain out.
I was going to use a speaker wire (fully jacketed, no metal showing) to push down through the drain tube to clear it out, but it doesn't go straight down. If I put my pinky in there, the hole seems to open up to a small cavity and then there's another hole on the rear side which seems to go down.
Is this right? Should there be a tube attached directly to the hole visible when the top open? Or is this cavity thing right?
Thanks,
Brent
If there are symmetric drains (i.e. one of the same on both sides of the vehicle), make sure the flow appears similar from both drains when testing.
IIRC, one can find the drain under the car, and perhaps blow it out with a bit of compressed air.
Just a thought.
Just a thought.
I tried to hose down the car to see if I could isolate a leak. Nothing. The car then stayed dry through a major rain storm overnight. Though I had solved the problem.
But then I drove to work and parked on an incline. When I came back at the end of the day I had some water coming into the passenger footwell. I'm puzzled, because the battery/frunk area itself seems to drain very quickly.
Did it today. Rear drains were in pretty good state, water flowing trough with no issues. Used a trombone brush from the first post, easily cleaned through.
Front drains were in worse state. Lots of debris. Was able to clean using the brush, water is getting through with no issues.
I don't have drain screens on my car. The rubber cap on front drains seems to perform the same function though. I found a D20 roll die, I guess one of previous owners was into dungeon and dragons
What's the consensus on using screens? Should I get them for my drains?
