987.2 2.9L P0084 engine light
Exhaust Valve Control Solenoid Circuit is P0084
Symptoms-
Shudder on idle- car has thrown P0300 P0304 P0305 P0306 which is multiple misfires, and then cyls 4, 5, 6. Engine goes into reduced power mode.
Car is near 100,000 miles so I am going to be replacing the plugs and coilpacks soon, but that is odd that all 3 are misfiring.
Any thoughts on the P0084? Could it be related to a misfiring single cylinder?
Symptoms-
Received 1,150 Likes
Replace the plugs (and you might also consider the coils) then reset the ECU and see what happens. It has been my experience that when one coil starts misfiring it somehow can cause other coils to also misfire. Solution is usually plugs and/or coils.
That's the plan. The code that is concerning me is the solenoid cause it looks like to be a not easy fix if it is indeed that variocam solenoid
BTW - when asking for help and listing codes - please also list the description of each code (the simplest OBD-II tools will give you that) rather than assuming people are familiar enough with the code numbers that they know what each code you list means. Most of us aren't and don't feel like going to look up the codes - so answers you get have to be considered as possibly inaccurate based on lacking information.
I'm guessing you're not reading the codes with a Porsche specific scanner? If you were - something like DuraMetric and iCarScan allow you to read the "Expected Cam Angle" and the "Actual Cam Angle" - that will quickly reveal if there is any problem in the Variocam system. You may want to seek one out - perhaps someone local to you owns one and would read out ALL the errors stored in the modules, and the cam-angle information. That would require revealing where you're located and for some reason, it seems people are really paranoid about doing that.
P0084 Powertrain - Exhaust Valve Control Solenoid Circuit (Bank 2)
P0300 Powertrain - Random/Multiple Cylinder Misfire Detected
P0304 Powertrain - Cylinder 4 Misfire Detected
P0305 Powertrain - Cylinder 5 Misfire Detected
P0306 Powertrain - Cylinder 6 Misfire Detected
As an update--
It was the VVT sensor that is found between coil packs 4 and 5. I took it out, gave it a solid cleaning with brake cleaner, and applied some 12v to it, and it freed itself.
Everything is whirring along good!
The following 2 users liked this post by Libast:
A432 (12-30-2020),
ZuffenZeus (10-18-2020)
