Hello all, so I just did my AOS, oil cooler, AOS vapor lines, and some other stuff.
I have the car back together but...I can't figure out where this plug goes? Don't see anywhere to plug it in. I have the shop manual but can't figure it out.
Anyone know? Would love to finish soon!! Drivers' side of engine
Do you remember unplugging it? It may have been unused. I would look for a connection under the intake plenum.
Found it! No I didn't unplug it. It is indeed the evap connector under the driver's manifold. I didn't remove manifold and didn't unplug it. Possible it was never plugged in? Anyway with a mirror and patience, plugged it back in. Thanks
Found it! No I didn't unplug it. It is indeed the evap connector under the driver's manifold. I didn't remove manifold and didn't unplug it. Possible it was never plugged in? I only very recently got the car. My second Boxster. Pretty sure the car would have run with it unplugged. Anyway with a mirror and patience, plugged it back in. Thanks
Porsche doesn't put extra wires in their cars. It was used and plugged in - you can tell by how clean the green gasket and the contacts are.
Sometimes they do. For example in 981s with base exhaust, the plug that would go to the vacuum solenoid that actuates PSE hangs around in that location unused.
My 987.2 also has this unused plug but it does "plug in" to some kind of blank receptacle.
