Need Help : Cayman R Springs in Cayman S
I got a set of 2012 Cayman R springs for my 2010 Cayman S.
No issues with the front but my workshop is struggling with the rear in that the R springs are much shorter than stock springs and they are not sure what to do.
The shock absorbers for both 2010 Cayman S and 2012 Cayman R are the exact same part number.
Anyone done the same and can advise?
Thanks.
Thanks.
First of all the struts / shock absorbers are not the same in Cayman R and Cayman S (and part numbers differ). The R strut is shorter and has different rebound / compression. Second, its never a good idea to stick shorter springs on a strut that is designed for a taller spring - it will stress the shock causing premature wear and will affect driving characteristics in an unpredictable manner. If you really want to use the R springs, you have two choices: use R shocks or use Bilstein B8 struts which are designed for lowering springs.
I just did this over the summer using Cayman R springs with Bilstein B6 shocks; worked out great. I think the B8 shocks can work but they're really meant for aftermarket springs that lower the car beyond the Cayman R drop.
Parts List:
Front Damper - Bilstein B6 (x2)
P/N 35-122180
Cayman R Front Spring Set (x1)
P/N 98734353140504
Front Strut Mount (x2)
P/N 99734301801
Front Shock Bearing (x2)
P/N 99634351505
Rear Damper - Bilstein B6 (x2)
P/N 35-122197
Cayman R Rear Spring Set (x1)
P/N 98733353196504
Rear Shock Mount (x2)
P/N 98733305900
Rear Strut Bushing (x2)
P/N 98733350400
More details here.
Parts List:
P/N 35-122180
P/N 98734353140504
P/N 99734301801
P/N 99634351505
P/N 35-122197
P/N 98733353196504
P/N 98733305900
P/N 98733350400
More details here.
Liongolfer (12-11-2019)
its really confusing.. Individual part numbers for the R and S dampers I have now discovered are different BUT for the damper kit ie set of 4, the kit part number for both 2012 R and 2010 S are exactly the same. Then I look to bilstein OEMs on ECS and FCP Euro and have now also confirmed with Bilstein USA, the B4, B6 and B8 dampers for both 12 R and 10 S are exactly the same. SO what I'm wondering is IF the 2012 R takes the same B4 and B6 as the 10 S, and using the same shorter R spring, why is it ok on the 12 R and not the 10S?
Parts List:
P/N 35-122180
P/N 98734353140504
P/N 99734301801
P/N 99634351505
P/N 35-122197
P/N 98733353196504
P/N 98733305900
P/N 98733350400
More details here.
Parts List:
P/N 35-122180
P/N 98734353140504
P/N 99734301801
P/N 99634351505
P/N 35-122197
P/N 98733353196504
P/N 98733305900
P/N 98733350400
More details here.
Did you DIY?
If indeed the B8 wil lower the car even more than the 20 mm, that's not what I want too. I'm really confused now.
Yes, I swapped them myself.
There is a lot of free play when the R spring is on the stock strut and a lot more so on the rear such that the R springs don't sit tight at the bottom and top of the strut. I'm struggilng to find the right technical terms.
As my rear left strut is very near its end and if I have to get new struts, I'm thinking B8 to take all the guess work out as B8 is made for lowering springs. I'm just concerned it going B8 will drop the height even more than 20mm which I don't want.
Don't take this wrong, but does it make any sense to change out the springs and try to match them to different shocks when the whole spring/shock assembly is readily available as a package AND that package was developed for exactly the car you want to put it on? You can bolt in the Cayman R suspension to any 987 (I have it on my Cayman R and bolted it on my '07 Boxster S) with zero issues.
I have no idea if the Bilstein shocks were valved he same as the shocks in the R suspension (also called the x73 in the 981 chassis), and suspect neither does anyone else. So even if they fit and get you the drop you want, you will likely end up with a confused suspension. The Cayman R/x73 setup is widely considered to be astonishingly good, why not use it?
Just my 2 cents.
Just my 2 cents.
The following 2 users liked this post by andy7777:
9872SpeedYellowCS (12-17-2019),
tomhartzell (12-12-2019)
Now I'm even more confused as the B6 and the B4 (which is the stock strut) are the same length/height and hence the R spring should fit the stock strut (b4) as well if it fits the B6?
The B8 shocks may work (a Bilstein rep can confirm) but I can guarantee you the B6 shocks definitely work.
Just my 2 cents.
Just my 2 cents.
Its definitely not what Porsche had in mind but I think (hope) the R spring Bilstein route will still be good per the experiences of quite a few. I'm reading the original Porsche shocks are made for Porsche by Bilstein so it should not be too bad going with Bilstein.
When you say "free play" on the springs, is this with the car on jack stands or a lift? Is the suspension unloaded? Because if so, the shock will compress and the shock/spring assembly will become tight once the car is on the ground. I noticed this too in the rear with the R springs on the B6 shocks, but once I lowered the car, everything tightened up and works perfectly.
Bilstein has confirmed B8 is the way to go but interesting that they also did not say an absolute no to B4 and B6.
In any case, now that I also have a very near end of life rear left shock and will have to change shocks regardless, I'll go B8 as Bilstein has confirmed it'll work for the R springs, my workshop concurs. Bilstein has also confirmed that the ride height is determined by the springs so a shorter strut like the B8 wont' lower it any more than the R springs are meant to lower.
Thanks for chiming in kiznarsh.
The struts have a range of travel that is optimal for a given ride height. The body length and stroke of the shock need to be sized so that the travel is centered at the ride hight dictated by the spring. It's possible the B6s (or stock strut) work ok, but they may also have reduced compression travel (and more droop travel) at a lower ride height than a shorter strut would because the car is sitting lower in the strut's range of travel. If Porsche pairs a shorter strut with the R springs and Bilstein recommends the shorter B8 strut, that's the way to go for optimal range of travel.
Or maybe these struts have a wide range of travel and a 20mm drop is inconsequential.
Parts List:
P/N 35-122180
P/N 98734353140504
P/N 99734301801
P/N 99634351505
P/N 35-122197
P/N 98733353196504
P/N 98733305900
P/N 98733350400
More details here.
Parts List:
P/N 35-122180
P/N 98734353140504
P/N 99734301801
P/N 99634351505
P/N 35-122197
P/N 98733353196504
P/N 98733305900
P/N 98733350400
More details here.
I am on the hunt for a 987.1 and debating heavily over PASM vs non-PASM car. I have both options available as there are plenty of specimens available on the market. I go back and forth as to whether I want to be 100% connected to the road (non-PASM) or whether I want the car to have an option of a smooth ride on longer trips. The car won't be a DD, because I work from my home office. However it will be taken out several times a week for "fun" rides. Maybe 3-4 times a year it will go on 3-4 hour trips on the interstate to either the coast or the mountains (I am in NC).
Suspension upgrade would be one of the first things I would want to do in either case. For the non-PASM I believe I would want to do exactly what you've done here, and for a PASM car again the same thing except with the Damptronic version of the B6, plus the DSC controller upgrade.
Thoughts? Thanks !
I wonder has anyone done this exact setup -- Cayman R springs with Bilstein B6, but on a PASM car using the Damptronic version of the B6 and of course the DSC controller upgrade?
Thoughts? Thanks !
Thoughts? Thanks !
Was in the market for CR springs to fit on the PASM thinking it would go another 10-20mm lower. seems like I might have to use H&R PASM compatible Lowering Springs.
Getting control arms, ARBs and links to sort out the handling side of the Cayman.
Thoughts? Thanks !
Thoughts? Thanks !
