I'm back
The diagnosis from the dealer for the fault codes are a misfire from cylinder #6. They are replacing the coil and plug. Also they said the oil filter canister house and oil pan have a leak. Not just the canister but they say it is the housing for the canister. They claim that is a 10 hour job to drop the pan r and r. Seems overboard. Any thoughts
David
David
10 hours seems incredibly high. I've done an R&R on my M5's oil pan that had nothing in the way of it dropping down and looks like ours is the same way.
Unless I'm missing something, it's just removing the bolts holding it to upper pan/block. Cleaning off the gasket residue, putting on a new one and torquing the bolts again. Got a good indy shop around?
I see it that way also. I got the car from CarMax which has a 30 day warranty. They took it to Irvine Porsche to figure out the code and mentioned the leaks. We'll see what CarMax has to say. I think Irvine Porsche is soaking CarMax.
Good to know you personally won't be responsible.
Does CarMax require you to use this dealer? I’d make contact with the local PCA chapter and see who the good Indy shops are in your area.
On the other hand it never hurts to fix oil leaks, especially if it’s not on your dime.
Update. Number 6 coil replaced and as for the oil leaks they said it was a sloppy oil change. Leak at the drain plug and leak at the filter canister o ring seal. All re done and no leak or smell of oil. I have noticed the slightest hesitation when passing 3000 to 3200 RPM's. Very slight but I feel it. I read a little about variocam possibly being the culprit. Any experience with this?
.deleted
