Oil Change
Old 10-20-2017, 12:25 PM
tomc66
tomc66's Avatar
Default Oil Change
I just traded in my 2011 911 for a 2018 Cayman. Do you access the oil filter and drain plug from under the car? What size wrench is used for the oil filter?
Old 10-20-2017, 01:55 PM
deilenberger
deilenberger's Avatar
Received 1,143 Likes on 759 Posts
Post
Cayman <> Cayenne. Moving your post to the Cayman forum.
Old 10-20-2017, 06:22 PM
extanker
extanker's Avatar
2018? ....i would let the dealer sort out this dilemma before you void the warranty
Old 10-20-2017, 07:00 PM
tomc66
tomc66's Avatar
Changing the oil yourself does not effect the warranty.
Old 10-21-2017, 01:41 PM
Macster
Macster's Avatar
Couple of ways to approach this. Visit the local Porsche dealer and talk to a service tech. I have found over the years they are pretty helpful. They can't make you a professional tech but they can help you do proper servicing.
Or at the dealer buy a spare oil filter housing and then take it to an autoparts store and try filter wrenches until you find one that fits.
Early in my Boxster ownership I bought a 2nd filter housing to have just in case the one on the engine got damaged.
What I'd do is use the other one -- it was clean of course -- and then the used one I'd clean up later and have ready to next time. So every time I changed the oil I alternated between the two housings.
At your favorite autoparts store ask if you can buy a number of different oil filter wrenches to try with the understanding you can bring the ones that don't fit back for a full credit.
You want to be sure you have all the necessary parts for an oil/filter service. Proper amount of oil. New filter element. If the housing requires o-ring(s) (and I think it does, at least the one on my Boxster and Turbo does) you want these. New oil drain plug *sealing* ring.
I bought a few spare sealing rings along with a spare oil drain plug to have just in case.
When I bought a new filter element at the Porsche dealer parts counter I'd get the element with the o-ring inside the box and a new sealing ring taped to the outside of the box.
The last I heard the DFI engines have a one hour drain time. The new Cayman (and Boxster) 4-cylinder engines I don't know what the drain time is for those engines. Ask the tech.
Old 10-21-2017, 02:07 PM
zedcat
zedcat's Avatar
You can get the oil filter wrench socket from Suncoast Parts. Also the filter kit.
Quick Reply: Oil Change
