cupholder door
cupholder door
Probably another newbie question. My cupholder door (above the glovebox) is difficult to latch. I never use cupholders, but curious passengers have opened that door, and I have great difficulty getting it to latch closed again. Is there some technique I'm missing, or is there some adjustment? Carbon fiber trim pkg, it that makes any difference. 2011 Cayman
Bill, not sure if this will help, but when closing the trim piece to retire the cup holders you need to make sure you are pushing it in as far as it will go. If you don't push hard enough, the trim piece won't close the first time and you end up opening and closing it two or three times before it ultimately engages and remains closed. Also, I've found that if you put your finger in the dead center of the trim piece when you push (on my trim piece there is a beverage sticker right in the middle), that is the "sweet spot" as the latch is directly behind that in the middle of the trim piece. If you try to close it by pushing from the right or left of center, the chances of engagement the first time lessen in my experience because direct pressure on the latch itself is not being exerted. Give it a shot. Good luck.
Also, I've found that if you put your finger in the dead center of the trim piece when you push (on my trim piece there is a beverage sticker right in the middle), that is the "sweet spot" as the latch is directly behind that in the middle of the trim piece. Give it a shot. Good luck.
Thanks guys. After doing some more research, this is apparently a pretty common Porsche problem. As I said, I don't use the cupholders anyway, so I'll just try to alert passengers the keep their hands off.
If there was a way to "permanently" latch it closed, I would do that.
Thanks guys. After doing some more research, this is apparently a pretty common Porsche problem. As I said, I don't use the cupholders anyway, so I'll just try to alert passengers the keep their hands off. If there was a way to "permanently" latch it closed, I would do that.
Once it becomes difficult to latch it will soon break and not lock closed. The internals are really cheap plastic. What breaks is a very tiny gear that lifts the locking latch as the door closes. Now you can manually lock the cup holder once it does break. On the right side of the center post is a tiny white latch lever, unwind a paper clip, hold the lever half way and close the door. Once the door engages the lever pull out the paper clip and finish closing the door.
A replacement cup holder unit costs about $300
Thanks for that. I had found the "latch lever", but hadn't yet figured out exactly what role it played.
I have no interest in replacing the unit, at any price. Even if it worked, it's clunky and inconvenient, IMO. As long as it stays shut, I'm happy. I may consider some double-sided tape, if necessary.
I have no real need for cupholders for daily drives, and I bought a $10 piece that slips between the seat an the console I can stick in if I feel I need something for longer trips.
