Break Rotor issues - 2016 Spyder
Brakes are really very poor on the Spyder compared to the GT cars. I've done six track days and am now at 6k miles.
So far I've replaced:
2 x front pads
1 x front rotors - cracking
2 x rear pads (blame torque vectoring)
1 x rear rotor - warped / flat spot / or something
Not found an aftermarket solution as yet - I'd be pleased to hear suggestions
2 x front pads
2 x front pads
2 x front pads
Also, your rear pads will prematurely wear if you use PSM while tracking. Is that different than torque vectoring?
Upgrade to a better track pad like a PFC11 or an Endless ME20. They should provide you better initial bite, less fade and will last a bit longer.
Sorry, didn't take pictures before throwing them away but over 7mm from drilled holes and so a risk. Sadly torque vectoring is not disabled in the 'all off' setting. Have tried a number of retailers for race pads with no luck, I suspect because Porsche may use separate part numbers for the Spyder brakes despite being 991s parts.
2 x front pads
2 x front pads
Upgrading to track pads will roast the drilled rotors even faster. I'd be willing to bet a six pack that there are several good options for upgrading the Carrera S rotors and pads. I'm thinking girodisc, performance friction, pagid. Might give these places a call.
Are the rears 991s pads/rotors as well? Would make things much easier. I called suncoast this weekend just to check on things and the fronts are the same...they seemed a little iffy on the rears. FWIW on the 991S I would routinely get only two days on the OEM pads and 4-6 out of the pagid rs29's. For the prices (doing the math over an entire season) I stuck with OEM rotors and for how much of a pain in the rear it was to change pads I went to pagids (or any other durable/squeally pad of your choosing).
I'm picking up another set of rear pads and rotors from Porsche tomorrow so I will check the part numbers and post them here.
Front pad 991.351.949.02 uk price £200.40
Front rotors
991.351.403.01
991.351.404.01 uk price £215.80 each
Given the relatively high cost of moving to racing specification parts I'm not sure if I'm better just using the Porsche parts and accepting the need to be replaced more frequently. Standard braking performance it's not horrendous, although there is a bit of fade towards the end of a long heavy session.
Consumables in the form of rotors, pads and tyres are running at about £450 per track day!
Front rotors
991.351.403.01
pads/day seemed a wash for me, just got to change them less often with racing pads. Also noticed less "outgassing" (or whatever) on large/high speed tracks with race pads. Again, rotors on the s just didn't make much sense...and not all that much harder to change than pads with a floating caliper. Would look into tarrett engineering for caliper studs if you are going to track often, those caliper bolts suck. would love to hear specifics on the rears.
I've used Performance Friction 08 compound pads with excellent longevity. Some of our local club racers use them for enduros. The main downside is that they put a lot of heat into the rotors, so you will be better off using non-drilled rotors. I have heard that the PF 011 compound is a bit more rotor friendly, but have no direct experience using it.
Former Vendor
RacingBrake has 380/380mm rotor kit that you can upgrade to for extra thermal capacity, save the rotor and pad wear. Fully compatible with stock 6/4 pot caliper and stock pads
http://www.racingbrake.com/RB-Iron-R...por-irk-14.htm
Detailed in this thread:
CS/GTS BBK with GT3 Size Rotors
https://rennlist.com/forums/991/9152...ze-rotors.html
The most effective and affordable for instant BBK and never have to worry about out-braking your stock brake again.
