981 cayman GTS GPS based PSE valve control
Many of you probably already seen the 991 GT3 PSE GPS valve controller DIY. I had posted a 981 Cayman PSE GPS valve controller DIY based on the 991 GT3, however there is an error in my DIY direction and I decided to write up a new set of instruction for 981 Cayman GTS and I will do the same as soon as I get my hands on 981 cayman GT4 in a few short weeks. To clarify Do not use 991 GT3 directions for Cayman or any other vehicle as I have not personally confirmed whether they work or not. Proceed at your own risk! If you blow up your ECU, which is extremely unlikley, please do not blame me. Ok... now on to the good stuff!
https://rennlist.com/forums/991-gt3-...nd-checks.html
Please read this post first and then see the below modifications
1. Open up the hatch and remove engine cover. I will not go into details of this. There is good directions on planet 9 and you can google it.
You should get this
You should get this
To build the wiring harness, you will need to get the supplies as listed in the 991 GT3 DIY
Because the Cayman GTS PSE valves works differently than 991 GT3 the Harness is different
+ wire will be the Pass through as voltage does not change. Thus, the red wire in the wiring harness is the V+ and it does not change so the red wire will be connected to both plug on the positive lead
Red wire will be connect on the same side on both end of the port
When facing the female side of the plug with metal spring wire on top, please note the Right side plug is V+
This is from 991 GT3 wiring harness
So instead of the black wire (V-) being the pass through, the Cayman GTS is using the Red wire, which is (V+) as the pass though
Step 2 - build the processor board / relay board / GPS board stack
The processor board, relay board, and GPS board all simply plug into each other. But before you can plug them all in, you have to solder the pin headers onto the GPS board, and solder one extra jumper wire onto the board for the GND to drive the solenoid on demand.
Carefully snap the pin headers into the appropriate number in each group to match the holes around the perimeter of the GPS module, assemble them from underneath, and solder them from above. When done it should look like the picture below (note that this picture is the final assembled stack):
Now extend your blue and black wiring from the solenoid harness either directly or through some intermediate connectors and jumper harnesses and route them into these specific terminal connections on the relay board shown below (terminal block 2). It’s important to get these exactly right:
- the “NO2” (Normally Open 2) should connect to the GND wire connection you soldered to the GPS board. This is the GND source.
- the “COM2” (Common 2) should connect to the -V_solenoid-side blue wire connection from your solenoid wiring harness
- the “NC2” (Normally Closed 2) should connect to the -V_ECU-side BLACK wire connection from your solenoid wiring harness
It’s important to use this specific terminal block since the software that will run on the processor board is only designed to flip this specific relay. Goofing up this wiring might damage your ECM if you accidentally short the battery voltage to the ECM-side connection, so triple check everything and of course proceed at your own risk!! Here is what the connections should look like when done:
This is the main difference between 991 GT3 and 981 Cayman GTS. Big thanks to @Mech33 who walked me though this entire procedure. I also borrowed many photos from his DIY. I hope this helps the community. I will update or put up a new thread when I get to the 981 GT4!.
Please read the rest of the 991 DIY for how to program and such!
Good luck and see you at the track! MRLS specifically!
Very good timing, sir! I wanted to locate that solenoid on my car... Thanks!
Afterwards in a dyno environment the car was having ignition timing issues/pinging with the valves forced closed but this was with an aggressive ECU tune and a very hot dyno environment. Out on the track it seemed to work fine.
