981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
2014 Porsche 981s intermittent starting issues
Old Jul 30, 2024 | 01:42 PM
Aakash Shah's Avatar
Aakash Shah
Default 2014 Porsche 981s intermittent starting issues
Hi everyone,
50k miles
Have been having intermittent starting issues since last week. Battery is new oem replaced less than 2 years ago. Currently at my indy being diagnosed but they're having trouble pin pointing the issue and have not come to a conclusion As it Dosent seem to be the battery. Any ideas or anyone else have similar issues before? Thank you!
Old Jul 30, 2024 | 09:20 PM
marques's Avatar
marques
We need a little more information. Is the starter turning the engine over at a strong pace, or kind of struggling? Trying to narrow it down to the battery or something else. Just because it’s only 2 years old doesn’t automatically mean it’s 100% healthy….
Old Jul 31, 2024 | 10:01 PM
Larson E. Rapp's Avatar
Larson E. Rapp
The fuel pump relay can do this. What codes are being reported?
Old Jul 31, 2024 | 10:14 PM
Aakash Shah
No codes being thrown. Have a video of it failing to start. But can’t upload here. Currently car is at my indy and they are diagnosing. Making sure to rule out all culprits besides the battery. When car starts the battery voltage measures good. When it Dosent start it measures as dead. Quite the difficult issue to pinpoint
Old Aug 1, 2024 | 12:54 AM
thecajunboy's Avatar
thecajunboy
From: South Louisiana, Bonfire Capital of the World
I see you read through the other thread where someone is having starting issues. We can't help if we can't get real and well described symptoms. Sorry, but if you tell me the battery measures good sometimes and at others it measures as dead, I'm gonna have some trouble believing that is truly the case. We would need to know exactly where and under what conditions those voltages were being read, the specific numerical value, and if the battery is being recharged in some way after a dead reading.
Old Aug 1, 2024 | 07:45 AM
Aakash Shah
I can let you know the specifics when I find out more from my indy. If you have a place I can send you the video that would probably help. When you try to start it it’s quiet you don’t hear anything. Dash lights do flicker. Other times when it does start it fires right up. No lag. When the battery is dead they have been able to start it with a jump or trickle charge for a few hours. When they do test the battery voltage when working it measures as a normal battery. I believe over 12.5 volts
Old Aug 1, 2024 | 07:48 AM
Aakash Shah
Realistically I know none of you will be able to tell me my exact issue. Just looking to hear other peoples experiences with the same car and starting issues and possible causes. So I can think about focusing on testing those issues and ask indy to do load tests and check for any parasitic draws etc. The below is what I know it could be
battery
starter relay
starter
alternator
fuel pump relay
fuel pump
dirty battery terminal and starter connections
Old Aug 1, 2024 | 09:02 AM
thecajunboy
battery
starter relay
starter
alternator
fuel pump relay
fuel pump
Based on your comments it seems that the battery voltage is insufficient when the problem exists and needs to be replenished to get things to work again. If that's really the case, then the battery should be the first item assessed. A full charge and load test is in order. I'd pull the battery to do this and check/clean terminals. Actually at this point I'd consider a new battery to cut labor hours at your indy and peace of mind at the same time. Once the battery condition is proven as good, move on to other potential causes if the problems persist. If voltage continues to drop, you'll have to find the cause, and it may not necessarily be in the start circuit.
Good luck. Keep us posted.
Old Aug 1, 2024 | 09:34 AM
marques's Avatar
marques
Could be something as simple as battery terminals that need to be cleaned/retightened. Or could be something else. But it's very hard to believe the battery may be OK now and "dead" 10 minutes later, then OK again...
Old Aug 1, 2024 | 01:06 PM
TimD's Avatar
TimD
Do you have a manual trans? If so could be clutch disconnect switch.
Old Aug 2, 2024 | 01:38 AM
Aakash Shah
No manual. It’s pdk. Yes I find it hard to believe the battery starts sometimes and is dead other times. But that’s my situation right now. The next step is replacing battery under warranty at this point. If the problem still persists we will diagnose any parasitic draw further. I know one 981 forum owner where the parasitic draw issue was the instrument cluster. I also know someone with a 981 who had similar issues with the culprit being the starter relay. I made sure to eliminate any accessory devices such as radar detector and dash cam being the culprit of the parasitic draw Could be anything at this point
Old Aug 2, 2024 | 12:43 PM
t-design's Avatar
t-design
Basic Sponsor
Second that. HP fuel pump will look like a weak battery on start. I went through couple batteries before HPFP was diagnosed
T-Design9 : Mods and ergonomic accessories bespoke designed for Porsche cars
Memory Modules : remember SC **** settings; A/S/S, PSE, Spoiler, Sport/+ buttons
Phone Mounts : keep your phone up and close and charged
Cupdholders, Sunglass Holsters and more at T-Design9.com
Old Aug 2, 2024 | 01:57 PM
Aakash Shah
Indy concluded the battery needs to be replace. They diagnosed for a week. Hopefully that is the culprit. Will keep you updated if anything changes
Old Aug 2, 2024 | 04:13 PM
Aakash Shah
Wild fact. Porsche requires their customers to use a battery tender at all times in order for their battery warranty to be applicable. Apparently it’s a stipulation. They even made me provide a receipt of my charger.
Old Aug 2, 2024 | 05:33 PM
Osiicks's Avatar
Osiicks
I had intermittent starting issues and electrical gremlins when I bought my 981S - date on battery showed about 2.5 years old. I went on vacation and car sat for a week, when I came back, battery was dead, had to jumper the contact in the fuse box to open the frunk. I replaced the battery, registered it with my Foxwell, and all starting and electrical issues resolved. I understand these cars are VERY sensitive to battery condition - my 2016 CLA250 Merc is even worse.
As a side note, I am in the US and I replaced with a Walmart AGM - these cost significantly less than OEM, are high quality, are made by Johnson Controls - who also makes batteries for OEM and other "name brand" batteries. The Walmart no-questions asked 4-year full replacement if defective warranty is unmatched by any of the autopart stores - I have received a brand new replacement at 3.5 years at no cost. Disclosure - I have no relationship with Wally World - other than they take my money.
Unless you feel better about having the Porsche OEM sticker on your battery, for a daily driver there are better options out there.
Hi everyone,
50k miles
