For those who have replaced the head unit…
I’m considering replacing the PCM3.1 with a different unit.
My question is - as there are various car functions now shown on the PCM, is there any important functions/screens you lose when changing over that can’t be then done using the trip computer screen in the instrument binnacle ?
Thanks in advance.
Thanks in advance.
I've been looking in to this as well, and I think the primary discrepancy is that you lose the factory TPMS. The aftermarket head units do have their own solution to this, but you have to replace the sensors with ones that the head unit can connect to.
Someone please correct me if this is wrong.
EDIT: See below. Thankfully this is incorrect!
This is how I am managing infotainment currently: https://rennlist.com/forums/981-foru...tegration.html
Thanks !
Here is a LONG thread about them. You can jump ahead to page 158 if you don't want to read all day. A couple members even created a manual to help others with installation and setup.
Has anyone done a CarPlay retrofit / Headunit replacement for 991.1 - Page 158 - Rennlist - Porsche Discussion Forums
Here is a photo of my unit.
If you have the factory TPMS it can still work and show up on the gauge cluster. I have installed the CHSTEK Android unit. The only items that I lost are the things that the head unit communicates to the digital gauge to the right of the tachometer. They are the radio station, phone connection, and navigation. All of those items will still work on the new head unit, they just won't show up on the gauge screen. My factory TPMS works just fine. You just need to get a unit that has the canbus with it. Not a standard aftermarket unit like Alpine or Sony. There are a few Android units out there that work well and look good.
I will likely give the CHSTEK unit a shot. The physical buttons seem to be a better match with the interior.
No, you would use the app on your phone via CarPlay or Android Auto for. Or you can install the app on the head unit itself but you would need to add cell service or connect to a hotspot on your phone. I listen to Sirius XM on CarPlay via my phone app.
Thanks in advance.
Thanks in advance.
@boxdriver How is the sound and display quality with the CHSTEK unit? Any audio, volume, static, or hissing issues? Any touchscreen issues, glitching, or crashes?
Thanks... are you referring to the small instrument cluster display or the one you have in the PCM? I was referring to the later. It normally shows you an outline of the line you are driving (somewhat useless) and the option to download the saved telemetry.
