Disable Auto-Blip | Boxster GTS 6MT
I lost a 2008 Boxster S as a result of a texting teenager who blew through a red light and crumpled my front end. That was a little over a year ago. I’ve been contemplating a replacement ever since and have a very strong fondness for the 981 Boxster GTS 6MT, which I consider to be a reasonable replacement and upgrade.
I’ve spent the last 3 months, not searching for a GTS, but instead searching for a method to disable the Auto-Blip feature when the car is in its most aggressive configuration (Sport+). I’ve read many threads, spoken to many people, and even reached out to Softronic (what I believe to be a premiere Porsche tuner) for a solution. Nothing.
I know this has been discussed before in other threads. I just needed to throw up one more Hail Mary pass before moving on and considering other vehicles. As silly as it sounds, this is a hard stop deal breaker for me.
Here are my questions:
1. Are there any other tuners that I should reach out to?
2. Are there any hardware changes that could accomplish my end goal?
3. Is there a way to simply keep the car in “Normal” mode, but manually activate all the features that are engaged with Sport+? I believe that PASM, PSM, Exhaust, and Start Stop can be manually turned on or off in any mode, but I think the throttle mapping, PSM sensitivity and Dynamic Engine Mounting are informed by the driving modes (Normal/Sport/Sport+). But I could be wrong about this.
4. Perhaps there is a backwards way for me to get all the benefits of Sport+ without actually selecting Sport+? For example, could I have a tuner adjust PSM such that it defaults to all the things included in Sport+, except the auto-blip feature?
Help me, Rennlist Members. You're my only hope.
David
David
I think you’re overthinking this. use Sport if you don’t want the auto blip feature
Sajan (02-18-2024)
Received 2,233 Likes
You can always disengage PSM too. That disables auto blip.
Yes, I have a hard time telling when the car is auto blipping in Sport-Plus at the very same time I'm heel'n'toeing / rev-matching, so don't feel a big need to deactivate it. I do wish the brake pedal sat a little lower with respect to the throttle.
That has been my biggest complaint about the car. Brake pedal is too high.
Thanks for the responses. Much appreciated.
Sounds like the general consensus is:
1. There's no good reason to not use the auto-blip feature. Most everyone agrees that it's wonderful and should always be enjoyed.
*It then seems a bit odd to me that the Spyder and GT cars (GT4/GT3) offer a way to disable this feature independently. Not sure what to make of that. Maybe GT customers just prefer more control?
2. There is truly no way to disable this (while keeping all the high performance PCM components active) through software adjustments, or hardware replacements. It's just plain impossible.
David
David
David
David
Agree that, to me at least, the performance delta between Sport and Sport+ is negligible.
And thanks for the feedback!
You can get an adjustable pedal to raise the throttle.
