Known Issues with 981 Base PDK Cars?
#32
So is this something to be more or less concerned about with age? My car has >80k miles on it and doesn't have the retainer, but also doesn't have any signs of leaking. I'm not opposed to spending the $40 but it'd be disppointing to create a leak by messing with the joint.
#33
Done and done with the Retaining Bracket install.
Dittos.. was really simple.
Note to QuickJack owners -
If you want to remove the belly pan piece (which I'm sure makes getting to that top bolt even easier), the two outside Torx T-25 fasteners end up blocked by the QuickJack rails.
So remove those two fasteners before lifting the car. I removed all the other T-25's, loosened the 10mm fasteners and then used the low profile QJ pucks to hold the belly pan open (instead of a piece of wood as mentioned by @Ernest72 )
Still no big whoop.
I put baby doll up on the QuickJack the night before so I could do the job cold, but sill leaked about 20ml of coolant in the process.
My battery powered right-angle ratched wrench made quick work of removing the old bolts and installing the new ones.
Again no big whoop.
Glad its done.
Thanks again to the group for the info share.
Still no big whoop.
Again no big whoop.
Glad its done.
#34
Location: On a pygmy pony over by the dental floss bush
#35
Location: South Louisiana, Bonfire Capital of the World
#36
I got my '14 CS early '22 and it didn't have the door card issue but after parking it outside at work for 2 summers both sides started to show some lifting so decided to get it fixed early. Call Pedro before you start packing the panels, he gives great advise for packing and shipping.
Got my door panels back from Perdo's Garage last week and they look great. They fixed it quick despite hurricane Idalia arriving the next day. Quick and economical shipping from the pacific NW to Florida.
Thanks Pedro glad to hear everyone was safe.
I've got 100000 kms now and no leaks from the coolant pipe but got the parts and will do the fix next spring.
