As one of my winter projects, I wanted to take some time and clean up the rear underside of the car. It appears that the previous owner did a few “home” oil changes and there’s remnants of old/dirty oil and grime that I wanted to clean up.
As I will have access to a friend’s 4 post lift, I wanted to do all the clean up then, as at home I only have ramps. My question is, can I remove this large brace piece without having any adverse affect to the suspension, alignment, etc? Looks like it’s only 10 nuts or so and looks pretty straight forward.
The factory service manual indicates that alignment check is required if this plate is removed. The long M10X35 fastening bolts in some of those locations are single use only and need to be replaced with new when reinstalled.
WM 421419 REMOVING AND INSTALLING SUPPORT PLATE (ALL MODELS) > REMOVING SUPPORT PLATE >
IMPORTANT NOTES ABOUT THE SUPPORT PLATE
Information
If the support plate -2- was removed or if the threaded joint for the diagonal braces on the rear-axle side sections was loosened, suspension alignment is then required (for all Boxster/Cayman 981 models) (contrary to previous instructions) . Not required for previous models .
