Small stones stuck between rear bumper and quarter panel
Hi guys,
I noticed some small stones stuck in the circled area below, tried prying them out with a sewing needle but failed. Has anyone experienced this or know of a way to clear them?
Thanks!
I like the compressed air idea. That makes sense to me. I clean out the stones from the inner rear fender lips every week when I wash the GTS. Each week they are full. Amazing. The roads are dissolving in Dallas.
To be more precise, I would mask the painted surfaces with a strip of tape, then direct the compressed air from the outside in, hopefully blowing the grit toward the fender well (since the grit got in from the inner side). BTW, I have a 981 Cayman Base and have never seen this problem.
Thanks for the compressed air and dental floss suggestions, will give it a try. I Will need to loosen the bumper slightly, does anyone know how I can loosen that area?
I too am baffled how these stones got stuck there in the 1st place, more like small sand. they are lodged in pretty tight. Perhaps it started with a single stone which created a slight gap which then allowed the rest to accumulate. Anyone else has encountered this before?
