Boxster Top Care
Wondering what, if any, steps I should take to prolong the top of my 2013 981 Boxster. The salesman, mentioned putting the roof up each night to avoid creases in the fabric and not using any harsh detergents on it.
Does anyone do something in addition?
THanks,
Mark
For normal car washes, i just use water and a gentle brush.
Once a year I've used RaggTopp to date on mine... OK with it but it doesn't repel water with beading as much as i hoped or thought it would.
Next time I treat it i'll probably give the 303 fabric convertible top care product a try.
Gently vacuum or lint-roller when I want the top cleaner. For deep cleaning (once per year), I use Raggtopp fabric cleaner with a very soft brush. Have to then rinse like crazy, follow with treating with the protectant.
I've found the Raggtopp stuff easy to apply indoors (no breeze), then push into the sun to dry between applications. Any overspray is easy to wipe away with some speedshine or your detailer of choice.
Used the Porsche brand stuff once. Seems to work well, but I gave up on it because A) i didn't like taping off the entire rest of the car, and B) fumes, lots of fumes...
With either, I use a good basic N95 dust mask to avoid inhaling mist.
On the up / down thing... I've heard folks, including convertible shop / upholstery folks recommend always storing car overnight with top up. I've left the top down for weeks at a time, frankly and not seen any difference.
Mine is '05 987 with 9x,xxx miles, so you mileage may vary.
Now onto the next question: Which short shifter and new cables should I get??? LOL, no need to answer I've been researching all the threads already on this.
BTW - chicken HAS to be dead when spinning it over your head. Try it sometime with a live one.. last time you'll do that. Perdue makes good ones,
I followed the video by AutoGeek (and I bought my it from them too):
The job was much easier than I expected. I will probably do the 303 in the future, as people say it lasts longer (and I like the roller application idea better anyway). Regardless, it was easy to do, so I wanted to let others know as well!
And the "Fabric Guard" which also mentions a convertible top but not UV protection: https://www.autogeek.net/303fabricguard.html
I assume the recommendation is the former, correct?
The reason I'm revisiting is that it rained today and the water is beading better, but not quite as well as I see from pictures/videos. So, I figure I need another coat (even though I used the full can for the RaggTopp stuff already)... so I figure I'd use the 303 this time around. I assume I can just put this over the RaggTopp stuff...?
