981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
Porsche 981 Engine Overheating Error! Temperature Sensor?
Old Feb 13, 2021 | 09:34 PM
MrMoose's Avatar
MrMoose
Yes. It doesn't really work effectively if there's liquid in the system. Also it'll spray coolant out the tool's exhaust and make a mess.
That said, I don't own a 981, but my understanding is that the proper 981 coolant bleed procedure requires using PWIS either during or after the vacuum fill. This is different from the 987. Not an expert here so you may want to verify.
Old Feb 14, 2021 | 12:34 AM
okie981's Avatar
okie981
From: On a pygmy pony over by the dental floss bush
I wondered if I needed PIWIS to do this vacuum fill procedure before I gave it a go after reading a few places that it was necessary on the 981 cars. Then I called a few shops that work on Porsches (including one well-known indy shop that posts on Rennlist regularly and does a lot of track car work) and they said PIWIS wasn't required on 981 cars. I didn't use PIWIS and it worked great, zero issues.
Old Feb 14, 2021 | 02:58 AM
deilenberger's Avatar
deilenberger
I'm trying to imagine why PIWIS would be needed.. the only reason I can think of is if it has "REST" heat - which is using residual engine heat when the engine is off. That's common in the bigger cars (Cayenne for instance) and they have an electrical water pump in one of the heater hoses to pump the heated coolant from the engine into the heater core. Maybe PIWIS is used to power up that pump if the 981 has one. You do want to make sure the heater core is filled - which means full-on defrost works best, with the ignition on but engine off.
Old Feb 14, 2021 | 04:35 AM
okie981's Avatar
okie981
No REST feature on 981 cars that I'm aware of. I didn't do any setting of heater or defrost controls from what my car is normally set at, and the ignition was off, so it wouldn't have mattered anyway what the settings were. I believe the concern about needing PIWIS is due to the DME-controlled coolant valves in various places around the vehicle. I assume either the flow control valves aren't completely water tight or they default to open with power (engine vacuum and electrical) off. Whatever the case, when you are allowing the coolant to be sucked back in during the fill portion of the vacuum coolant fill procedure, just let it sit for a few minutes after it first appears the coolant has stopped flowing into the car. There will be no issue according to several shops that do this with 981 cars (vacuum fill, no PIWIS) as a daily part of their business, and according to my experience (albeit a sample of one 981 car).
Old Dec 4, 2025 | 10:12 AM
Mutilatorxxx's Avatar
Mutilatorxxx
8th Gear
Thanks for the report.
Old Dec 5, 2025 | 03:30 PM
ttu1970's Avatar
ttu1970
FWIW...I just went thru some of the issues you have encountered with a coolant change, and after numerous start, warm up and cool down cycles, I was finally able to get those annoying air pockets out of the system. I noticed during this process, the ventilation heat would come and go.....now that the coolant level has stabilized, coolant temps have stabilized and ventilation heat is now stabilized as well. I too was aware of the vacuum refill tool and used it, but I don't think I was able to get enough vacuum and ended up with air pockets. I know from experience what a PITA it is to drain and refill the system, SO, my advice would be to continue with the heat and cool down cycles and see if the blockage to the heater core will eventually be bled out before you resort to another drain/vacuum/refill. Make use of the inline bleed valve until you see some positive results on the vent heat issue. Hope it works for you...maybe I just got lucky. I'm from the "old school-air cooled Porsche" club and still learning about these new fangled water cooled P's.
I just now see where you originally posted this subject almost 5 years ago.....you have likely solved the problem by now or given up. Anyway, maybe our collective experiences on this issue will be of some use to the next person who encounters this problem.
