Race Seat Setup for 981 Cayman S
Hi all - I'm looking for recommendations on a race seat setup for my 981 Cayman S (seat and mounting hardware) for track days. I'd like to stay under $1,000 a seat, which it seems there are several options from (OMP, Sparco, etc.). The OMP WRC-R (~$800 a seat) looks like it may be a good option. Might need the XL.
Anybody have any experience on how the OMP WRC-R and XL version fits in 981 and the quality, comfort, etc. of this seat?
As far as mounting hardware, can this seat or others be bolted directly to the 981 floor using side brackets, or is base plate like ones from Planted needed in addition to side brackets?
Thanks!
FG412
Thanks!
FG412
If it all possible you should sit in the seat because those extra larges can be really big I have an extra large I have a 34 inch waist and it's way too big for me it's more like for a 40 inch waist
Fastguy412 (02-02-2021)
I have a 2014 Cayman S and added a race seat last year. I have a Sparco Evo QRT std size and it easily fits (I agree with the above poster a try to find a seat that you can actually sit in for sizing; the std size evo is good for me at 6' 175 lbs with narrow hips and would be waaay too sung for anyone larger or wider). I have it mounted on a BBI seat base with a long 3 point belt receptacle (GT3 belt I think) and a Schroth 6 point enduro harness.
If you plan to drive the car on the street with the race seat, on the EVO seat, you have to run the belt receptacle inside the seat for proper 3 point belt geometry (a lot of people do not do this and have horrible 3 point belt applications that dramatically alter the belt path and I think they undermine the safety of the 3 point) so the belt does not lay across the top of the leg portion of the seat and instead snakes through the thigh holes in the seat. This routing is not super comfortable because it puts the receptacle between your leg and the seat - if the seat is snug to start, this makes it really tight; you might go up a size seat to give yourself some room. I know I am ranting a bit on this but I see so many poorly routed 3 point belts with race seats - it really bothers me!
Last thing is the airbag warning light. I believe you can have it "unmonitored" or turn the monitor off for the seat airbag done via the PIWIS system if you can convince a dealer to actually do this (mine won't because they feel it modifies the factory safety system and are not willing to do it). The other option is to swap the seat with no key in the ignition, put a resistor in the plug under the seat to trick the ecu into thinking there is an airbag and then you might be good. I have done this and did get an airbag light when the seat was in but after I swapped back in the factory seat, I could reset the light with my Cobb tuner. I also skipped the resistor to see what would happen and now have a permanent airbag light that will not go away even with the Cobb. I am not sure what the easy answer to this really is...maybe someone else has a good solution.
OMP HTE-R very good seat under $1K as the side head protection which I like. Also roomy enough but fits well. I agree sit in a seat with your helmet on. before you decide, For me I added a cheap back lumbar support pad for that seat and it fits perfect.
I agree with everyone above to sit in multiple seats to see which fits your body best (back length, shoulder height for harness, width, etc.) and to confirm which bolster height works for you.
If you want something easy, just buy the BBI seat base.
https://www.bbiautosport.com/product...and-slider-kit
Parts Needed (if you buy them separately)
- Side Mount
- Hardware
- Seat base (Not needed if using OEM slider)
- Slider (Not needed if using OEM slider)
- Program using PIWIS at 3rd part shop
- My local Porsche Dealer did not want to program this
- Durametric Pro or Foxwell NT530 (look this up on their website for your car model)
Appreciate the feedback. Good suggestions about sitting in the multiple seats before buying. Might be able to do this at the track once track days get going again. Will have to see if I can contain myself until then.
In the meantime, I found this website that has the dimensions for broad range of OMP seats...DiscoveryParts. Have to scroll down the page to see the dims. The seat inner width for the WRC-R is 390mm (15.4in.) and the XL is 415mm (16.3in.). No way my butt is squeezing into the standard WRC. Will need an XL.
I'm planning on sticking with the factory 3 point belt for now, so good points by Brewerbry regarding the belt receptacle position. I hadn't thought about the air bag light either.
Linda at Apex Performance has been helpful as well. She recommended some mounting hardware by Brey Krause and Planted. Also mentioned options for manual sliders, which my car has.
Wonder if there is a race gear shop near you. Here in Chicago area, we are very spoiled with John and team at https://www.northstarmotorsports.com/. They have a showroom with a number of seats on display to try out. Made all the difference for me in seat selection.
Also, wear what you’d wear while driving when you try seats on. Jeans are different than a nomex race suit, etc. It can make a difference if you like as snug a fit in the hips as I do.
Good luck.
Good luck.
Fastguy412 (02-03-2021)
If you thinking of a five point harness eventually and are interested in getting a harness bar for your car, I have one from BBi that I removed from a 2014 Cayman S that is for sale.
Also have the interior trim parts that were professionally cut out to receive the tubing that I can include.
Does anyone have experience with seats with the head restraints in street use? I was shying away from those seats because my car sees plenty of street use. I figured these would restrict visibility too much in regular street use. Headed to local shop probably next week to start seat/harness conversation and installation this winter. I was looking at a seat like the Recaro Pole Position. If I am spending the money to upgrade to race seats for safety purposes is it stupid to not get a head restraint seat? Thanks!
I'm also shying away from race seats with head restraints for this reason. My car will still see some street use and don't want any issues with impaired visibility. I assume seats with head restraint would also probably be illegal on street as well.
On another note, my neighbor recently picked up some used Recaro Profi XL seats. We dry fit one last night in my 981 Cayman. It fit the car and my frame nicely. Might go this direction.
Regarding OMP WRC-R XL, does anybody have experience with this fitting in 981 Cayman? I'm hearing this seat might not fit. When I look at the dims, it looks to be about 3" wider at the shell outer at the shoulder bolster "C" vs. the Profi XL.
The Sparco Evo has removable halos, which makes them a good dual-purpose fixed-back seat. There are a few seats out there with "open" halos that you can see through. Recaro had one. Corbeau and Momo have had one. Not sure if any are still in production.
Remember that fixed-back seats/harnesses/roll bars work together as a system. It is advised to install all together.
I can source seats and harnesses for you, if you're interested. Anthony@DriveFasterNow.com.
Fastguy412 (02-15-2021)
Major fail on their part, as I am not buying a seat without sitting my butt in it first (unless like some high end clothing or shoe stores they are doing free shipping and returns!)
I will chime in on actually sitting in a seat - you are spot on to do it! I too was looking at the Sparco Evo with the removable halos and when I actually sat in the seat, found it uncomfortable but also the shoulder belt positioning too low for me which I would have never caught if I had not sat in the seat. It sounds like it will be a challenge for you to find a showroom to sit in an actual seat but it is worth the hassle in my opinion!
So my lesson- you absolutely have to seat in some seats before making a decision.
