Anyone tried to DIY a splitter on a 981?
I'm looking for a splitter that will work with my dual duty 981, but most commercial offerings that are real splitters and not just cosmetic tend to also have some kind of vertical spacer to drop the splitter down closer to the ground. My car is slammed between the KW V3's, the LCA's, and running big caster, so my little rubber things on the sides of the bumper are already only 1" off the ground. Obviously, those already scrape all the time and it's fine bc they're soft rubber bits. The hard parts are quite a lot higher than that, so I currently do not scrape the plastic.
With the car as low as I have it, I can't handle dropping the splitter 2"+ (via spacers or whatever). I think I really just need something to go out horizontally without lowering it at all, if I can make that work with the curvature of the bumper, alumalite or something.
Anyone tried this? Other ideas? Thanks for reading.
PS: I'm planning on a GT4-sized wing, hence the need for substantial downforce up front.
I did notice that Getty makes a "street" splitter for 981 that looks like it would work, but it may not be aggressive enough to really change airflow a lot. I've seen zero reviews or pics aside from their thumbnail on their website, so not sure. I emailed them.
Thanks. I'm not seeing any Porsche's on his (your?) insta except his personal GTS, which has a diff. bumper shape. If he can mold up a 981CS splitter with little to no rise spacing I'm game if the price is right. I'm in TN, so not close enough to use my car for it.
I’ve been on the hunt too and the only splitter that I’ve seen would work for street and doesn’t look heinous is the TWL carbon splitter. But it’s so expensive for just a single carbon piece.
Yeah, I also don't want something expensive and fragile-ish like CF anyway. I'd prefer ABS or alumalite or something else with some give so it won't take as much damage from inevitable scrapes and bumps. Seems like there's a market for a streetable splitter that provides aero, but I can't seem to find one out there. It seems like a somewhat difficult DIY just due to the curvature of the 981 fascia, unless maybe you utilized the stock rubber air dam as part of the thing...
Getty makes good stuff for sure. I just can't use their normal race splitter or 3 piece splitter with my ground clearance (unless I trailered, which is not happening). The street splitter would probably work ground-clearance wise, but not sure it would provide enough DF.
