981 TPMS Doesn't remember pressures
Does anyone else experience the constant Low Tire Pressure warning? I reset by switching tire type/size momentarily to get it to re read, then it reads correctly, but next startup or two it's back to showing the warning light. Maybe bad sending units or batteries? My car is a 2013 so now 5 years old. Tires were replaced a couple years ago but didn't pay any attention to the pressure sending units; mistake?
Seems like only the rears randomly, but I'll watch. Are there batteries that can be replaced? Or the whole units? Hoping it's just a matter of popping the bead to replace; maybe a rebalance?
The unit is sealed. The entire sensor has to be replaced. Might as well rebalance the wheel/tire combo afterwards.
I have a similar issue on the left rear. Read that the system needs to be "reset" which could be done by changing the tire setting to winters, let it run on that for a while, then switch it back to summer. Worked well, then it went back to it's old self where it keeps on saying it's -4 below on but the pressure reading is right.
Are your pressures proper and it's falsely flagging them as low, or are they actually low? When I'm at the track I have the tires at 26psi cold and the TPMS warns me at the start of every session. If I do a re-learn on the way to grid it goes away for the session, but at some point it warns me again because it's just too low. At the end of the day when I put them back to 32psi and re-learn again it's happy until my next track day.
If you have access to Durametric I think you can directly read the pressures and temperatures from the sensor and see what’s going on.
