968 Forum 1992-1995
Oh great, coolant issue.
Old 05-31-2017, 09:20 AM
  #46
Boeing 717
Registered User
Boeing 717's Avatar
Originally Posted by thomasmryan
Probably an air pocket at the DME temp sensor.
Was the valve separating or a hose leak?
The valve housing had a crack.
Is the procedure to bleed the coolant system in the workshop manual?
Old 05-31-2017, 11:05 AM
  #47
mj951
mj951's Avatar
If not in the manual you'll find it here: http://www.clarks-garage.com/
Old 05-31-2017, 11:07 AM
  #48
thomasmryan
thomasmryan's Avatar
3-16 but it's the standard warm it up and crack the valve until you get a solid stream.
Jürgen sqeezes the lower hose and bleeds it like a brake system in one of his videos but a pressure tester also works well. This assumes the air bubbles have worked their way to the high point though. it's best to repeat the process over a number of drives.
Let it sit a few days and see if it releases a vacuum when you pop the cap. If not, patiently wait for the next smallest leak to reveal itself.
The quick and dirty method is to pump the system with just air and squirt soapy water on every joint. Putting a million pounds of torque on a worm clamp exasperates the problem as it over compresses the hose during heat cycles. Just a thin smear of hylomar works amazing well.
Old 05-31-2017, 03:07 PM
  #49
Boeing 717
Registered User
Boeing 717's Avatar
Thanks guys.
Old 05-31-2017, 09:42 PM
  #50
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
1. you have an infinitesimally small headgasket leak.
or
2. your H20 pump has begun to fail,
or
3. your little itty-bitty heater hose needs replacing (prolly time to replace it regardless)
or
4. hose connection
or
5. your pressure relief valve is open a crack.
or
6. your radiator going bad.
i have a nice spare radiator in storage, that i forgot about.
oh you solved it?
Old 05-31-2017, 10:24 PM
  #51
Boeing 717
Registered User
Boeing 717's Avatar
Yup, cleaned engine bay of all residual coolant. And just test drove it again. Problem solved!! No more coolant leakage. Glad it wasn't the oil filter housing.
Just bought 4 new firestone Indy 500 tires and putting cup 1's on in the next few days. Car is coming along.
Quick Reply: Oh great, coolant issue.
