968 Electrical Gremlins
Was trying to help a pal troubleshoot his white 94 968 today with a strange condition. The car looses battery voltage when underway, specially loosing the radio when shifting into second gear (presumably because the voltage fall to a level below the minimum that will maintain the radio alive). If it is stationary, it is fine and you can row the gears stationary with no malfunction. Cleaned all the grounds I could find, cleaned battery contacts, found no loose conections or grounded wires.
also, it has that ticking relay sound from the passenger side dash, when the a/c is working. Is there any way to get rid of it?
Amy ideas are welcome.
TIA
Jpr
TIA
Jpr
I would hook a volt meter with extended leads to the battery, place it in the cabin, and take a drive. It would be interesting to see the voltage drop across the terminals when the radio cuts out.
My suspicion...voltage regulator/alternator is failing under load.
