968 Forum 1992-1995
968 resurrection
Old 06-24-2014, 12:21 PM
dougs968
OkRider
dougs968's Avatar
Mine was a rescue also and in Amazon Green too no less. My exterior looks very similar to yours. You have a great project ahead.
Old 07-04-2014, 12:10 PM
firemn131
firemn131's Avatar
My son and I found all new hardware, bolted up all parts except crank pulley. As it turns out the pulley for the P/S was not with the parts that I got from the salvage yard. Went back yesterday, and searched high and low. No Joy.
Pulley is hard to find, over 120.00...Anyone have one they want to sell?
John
Old 07-07-2014, 04:56 PM
Dino V
Dino V's Avatar
Nice save, looking forward to seeing your project.
Old 07-07-2014, 06:26 PM
mbardeen
mbardeen's Avatar
John
For stuff like this, I like using DCAuto.. They have the PS pulley listed at a much more reasonable $25.
http://dcauto.gotdns.com/illustration/index/807614800
Old 07-08-2014, 05:39 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
Deja vu all over again!
This thread matches my own resurrection from a few years back. Things you are going to want to verify:
1) Water pump free. I suggest just replacing it with new and a thermostat as well.
2) Starter wire from elec box to starter. They get frayed, and will cause a jump start when the large line is touched. If you remove the loom cover, you will see bare wire there. Fix it now by checking my thread on it.
3) Don't even try the tires after sitting so long. Replace.
4) Within a few thousand miles, plan on replacing the brake/clutch master and/or slave(s). I had the clutch master and slave fail, the brake master fail, and one rear brake cup fail within a year of driving it. Just be ready.
5) Odometer gear will die from disuse. Another tread to find.
6) While the water pump is off, backflush the engine several times. You'll find gunk coming out for a while. Use high pressure into the block if you can to circulate well.
Keep us informed.
Old 07-08-2014, 09:38 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
the op is brave...
head off/hot tank.... looks bad enough on a Honda.
then you add rod bearings and really, should be considering doing the main bearings as well....
at this point, with the engine taken apart, you can see what's cooking.
then you're in a world of hurt sourcing parts from top to bottom.
if you're good with assembling motors, well, that's one thing....
if it were me,
I'd spend about $28 k, do an ebay gm/aluminum block/v8 and install a set of long 4th, 5th and 6th gears on the *transmission rebuild....
wouldn't be cheap, but you'd get 200 k miles and it'd be a blast.
*(w/ one of the 968 transmission gurus located right in eastern Mass).
Old 07-09-2014, 01:16 PM
RajDatta
RajDatta's Avatar
I was wondering, how long before the 8 cylinder commercial came on. Right on OD!
Old 07-09-2014, 01:58 PM
sydneyman
sydneyman's Avatar
lol.
Old 07-15-2014, 09:38 AM
firemn131
firemn131's Avatar
hahah. If all else fails, I may go to the 8 cyl. At this point it is a bare bones resto.
Doc,
A)Water Pump was new when they started the TB fail project 6 years ago. It hasnt seen use and spins free, I checked nut and bolt torque, all good.
A) Hahaha Starter wire was completely bare inside of harness. I found that a few weeks ago. New harness to be made tomorrow.
A) Yea, tires are toast..
A) Dont even want to think of that.haha . My 928 is calling me!
Thanks for all input, It is reassuring to have people that have "been there done that"
It definately helps me get a warm and fuzzy about the progress.
John
Old 07-29-2014, 02:03 PM
firemn131
firemn131's Avatar
I miss spoke. He did leave the intake cover off, but the cam cover was placed overtop the head. hood was closed. I took head off and inspected, also inspected everything I could with a flexible fiber optic camera. Looks OK. I thought about doing the Rod and Main Bearings. I have never done that before, and dont intend to pull engine just yet. My 928 is sitting with the engine out now, so it is first on the list to make daily driver again. I have a few years to work this with my son.
Do I need to pull engine to do those bearings?
Old 07-29-2014, 04:12 PM
mbardeen
mbardeen's Avatar
No. You can do it from underneath the car, supporting the engine from above. If you're going to do the oilpan gasket at any point, it's advisable to do the bearings at the same time. Other things to do "while in there" are motor mounts and oil pickup tube.
Edit: Sorry, rod bearings only. Main bearings require the removal of the crankshaft, if I'm not mistaken, and that can only be done with the engine out of the car.
Old 10-04-2014, 04:01 PM
odurandina
Team Owner
odurandina's Avatar
any updates?
Old 04-24-2017, 09:55 PM
firemn131
firemn131's Avatar
Wow, it has been a while.
I put the 928 back together. Crazy power and fun. It is my daily driver now.
968:
Son and I did the timing belt and seals.
built new starter harness
rebuilt or reworked injectors
timing with variocam
He bailed on the project so I let it sit.
NOT going to build it for him.
It is officially my car now.
time to get busy.
Just getting back into it.
Parts order went out today.
trying to find the hard water line.
then install the new harness.
Expect to really get moving on this in 2 weeks.
Old 04-24-2017, 09:57 PM
firemn131
firemn131's Avatar
Duplicate
Old 04-26-2017, 10:33 PM
docmirror
docmirror's Avatar
Roger carries a lot and knows plenty about 968. He's on vac until 5/9 but he'll be able to find the water line for you.
If you reuse the water pump, keep an eye on the weep hole for the first weeks of use. The shaft can corrode slightly, and you may see weeping. If so, plan a water pump.
The timing procedure for the balance shafts is Orwellian. Read the manual a few times, and you can use Clarks Garage website, to verify. Plan on motor mounts too. Will vibrate, and you will think it's the balance shafts, but likely the motor mounts.
Quick Reply: 968 resurrection
