Large coolant leak after stopping
Well everything went back together smoothly enough until I got to the refill. I went and borrowed a pressure tester from Autozone, filled everything up, bled the system and ran the car for a while but after I turned it off, I heard the annoying dripping sound. Luckily (I guess) it wasn't the HVC but it was the large hose coming off the water pump to the lower end of the radiator.
I tried to tighten the hose clamp but every time I added some pressure, there was a consistent drip. I am waiting for the car to cool down and I will loosen the hose clamp and try and look at the hose closer. I'm assuming I'm going to lose the coolant again...this time I'll drain through the plug!
Well everything went back together smoothly enough until I got to the refill. I went and borrowed a pressure tester from Autozone, filled everything up, bled the system and ran the car for a while but after I turned it off, I heard the annoying dripping sound. Luckily (I guess) it wasn't the HVC but it was the large hose coming off the water pump to the lower end of the radiator. I tried to tighten the hose clamp but every time I added some pressure, there was a consistent drip. I am waiting for the car to cool down and I will loosen the hose clamp and try and look at the hose closer. I'm assuming I'm going to lose the coolant again...this time I'll drain through the plug!
It's actually dripping right at the connection to the water pump. I can see it leak out near the hose clamp then sort of run down the hose and finally drip off. I checked all around the radiator (brand new btw) and everything looks dry so at least I have that going for me. The new radiator hose will be here tomorrow and will hopefully solve the problem. Too bad I got to drain all the coolant again, bleeding went well and I had full heat and the HCV worked great.
A bit of an update:
I got the HCV installed, no leaks there but then saw a leak from the lower radiator hose. Got a new one and put it on...no leaks so now I am going through a coolant flush. After carefully crafting an old milk jug to divert the coolant to the drain pan (worked great, btw) so I wouldn't have to remove the front belly pan, I realized I had to anyways because the lower hose clamp was turned so I couldn't get to it.
I filled the coolant system with distilled water, bled the system, drove the car around a bit then drained quickly after the fans shut off. Looked like mostly clear liquid so tonight I'll fill with 50/50 mix, bleed, drive it again, bleed again the top it off and I should be good to go... did I leave anything out?
