GAH! never ending small stuff to work on
Shameful Thread Killer
Now I have a screetch from the front of the car when I start and it's not the alt belt. I heard the alt belt screetch a bit and then it went quiet, now something else is making noise. I really hope it's not the cam belt tensioner.![grr](https://rennlist.com/forums/graemlins/cussing.gif)
OK, TB and roller job done. The idle roller above the tension arm was pretty sloppy. Wouldn't have caused a huge problem but that was the noise. Now I have to adjust the alt belt cause that slight squeal was back.
Next is a camber adjustment for the rear wheels.
Jeez, back in there again. I started to adjust the belt, and the AC pump was moving! Shut it down, took off the belt, and the tension arm and both the top bolts are missing. One is just gone, and the other was sheared off at the little finger fitting. Went back up there with new bolts and nuts on the back, new tension bolt, new belt, and set the tension with the gauge and it's finally done.
Everything I see has come up short. Next, will be the clutch master flex. I'm gonna tackle that with a reinforcement before it starts to go bad.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
and guys on the 944T forum give my **** for not wrenching the tb/bs belt or blueprinting 2.5 liter assturds.
and why the V8 engine is inexorably tied to the long term survivability of the 944.
nor am I thrilled about a life spent battling these demons with the 968. **** like this is precisely why.
it takes special talent the likes of Porsche/Ferrari/Aston/Alfa etc. to come up with performance/design schemes that are this ridiculous.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I hear ya. I had a fair amount of fun driving in CO, and with the AC working it's pretty nice to putt around in. But, it takes plenty of garage time to keep it going compared to other cars. I don't mind so much really, it's better than sitting on my butt watching Springer reruns.
I will admit, it is never boring with the 968. Always something to be dealt with or repaired. Currently, I cannot pass emissions. I removed the adjustable fuel regulator, header and exhaust to no avail. Put the original chip back in and still failed. I have tried everything, very frustrating. The stupid thing is that I did not pass by some minuscule amount. Like there equipment is really that sensitive. Please!
Team Owner
I was helping a buddy search for a Ferrari 355....
boy was that a wake up call. biggest **** turd ever. given, it's got the most gorgeous *** in automotive history....
it's not enough that the interior screams KIT CAR, or that you must endure those gay, '80s pop-up lights... or that the engines need to come out every time you change a belt or other duhicky every 4 k miles... no. for starters, the exhaust systems get so hot because of the garbage oem cats, that the pipes actually melt, causing holes, fires and the engnes to literally burn up.
look at all the 355s for sale, they're running aftermarket exhausts, but no worries, no sooner do you change them out (about $15,000), but you're just in time for the next bit of good news---that you'll take that $30 k overhaul now... so, people get wind of the horrors from their buddies at the country club, stop driving them at 12~14 k miles, swap out the crinkled swiss cheese exhausts, and look for a sucker....
and the Ferrari 360 ? you'll never believe it... they run too hot too.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
The F-355 was the first chassis of the next gen 8 cyl car after the 348. Sadly, the 355 was still a WIP when it was foisted on the market. Soooooo many defects still present. Possibly the worst has been the failures in the ex valve, guide and seat. One could say this is a back pressure problem from the sticky exhaust systems, but really, the whole thing needed to be re-designed. The 360 was an improvement but only a marginal improvement. Both cars should be skipped over unless you like taking the engine out each year, and spending ugly money on exhaust systems and head work.
I have the old 3.0 engine and it's a nice compromise of simplicity with CIS injection and decent performance for it's vintage. Lots of systems not present on my car that become nightmares on later 8 cyl cars.
I've been driving my 968 through Maine winters since 2002 and have found (save the pinion bearing) that it wasn't much of a maintenance hog at all. If it were I couldn't drive it.
Calling much of anything "gay" as a derogative these days is seriously, egregiously wrong.
I pretty much agree with John. At least in my case, the 968 has been very reliable, and hasn't required an inordinate amount of maintenance, at least for a 20-year-old car. A belt change every few years isn't that bad, and it's not too tough of a job for a DIY'er, which makes it a very inexpensive job as well. Now, as far as the Ferraris, yes I could see them potenitally turning into a nightmare of a money pit.
