Any Interest in the Camshaft Adjustment Gauge?
So, from my meager-but-growing understanding about this subject, the cam block tool allows you to set the relationship between the two cams without needing to pressurize the variocam. Seems like a good option, since pressurizing the variocam, especially with air, becomes less reliable as the variocam assemblies age and allow air to escape between the piston and the chamber wall, which prevents the chain from becoming fully tensioned. This potentially introduces significant error, since the WSM procedure assumes that the chain is fully tensioned. But the downside of the cam block tool is that you're relying on the accuracy of machining of this block, which I'm sure isn't a trivial matter to get exactly right. Pick your poison, I guess...
This tool is not a substitute for the tool that pressurizes the variocam tensioner. What you're thinking of is clocking the exhaust cam sprocket, aka 'timing the variocam'. http://www.porsche968uk.co.uk/techni...-timing-01.htm
This tool is just for when you replace the chain, to make sure you put the chain back on the right way. Most cams have the raised arrows you can refer to. If you don't have the arrows, you can make this tool out of cardboard - it's not supposed to do anything but show you the proper alignment.
