Taking out trans, can't get driveshaft to turn to get to coupler bolts
Good afternoon - I'm working on the green car, and I'm taking out the trans to put in a new seal at the back...I have the 4 trans bellhousing bolts out, the cv joints removed, and 2 of the coupler bolts loose...I just can't get the driveshaft to rotate so I can get to the other coupler bolt. I have the car in neutral on the trans and have the clutch pressed in with a block of wood, but the driveshaft will only spin about 1/4 turn. I even tried putting a CV and a wheel on and rotating it in gear, and that would do that same thing, go 1/4 turn, then the wheel would spin but the driveshaft wouldn't. It's an early LSD trans, does that make a difference? It definitely feels like the rotation stops from trans side, not the torque tube side.
I'm at a loss...any rennlist wisdom? Thanks!
