WTB: VarioCam Oil Feed Line Bolts
iPod Tamer
I am in desperate need of the two allen head bolts that hold the oil feed line on to the VarioCam unit inside the head. Mine decided to grow legs and walk away. PET does not show the bolts for some unknown reason and I am a stickler about OEM stuff so I really don't want to go to the hardware store. If anyone has a parts motor or spare variocam unit that I can have the bolts from you would be HUGE life saver.
OkRider
Colin, if you haven't found those cap screws yet, and you would like to stay with OEM hardware, I would check with your closest Porsche dealer. If I remember correctly from when I did my cams, those bolts are a 6mm x 1.0 pitch thread about 10mm long, 8.8 grade. This should be a very common size for many applications, not just the 968s oil pipe. Heck, the mechanics' probably got a box of good used hardware back there for all kinds stuff.
Doug
Doug
