Sagging door
Sagging door
Anybody ever have a door start to sag on their car? I am having to lift on the driver's side door a little to close it or push on it with some force. What are the possible causes and solutions? Thanks.
Open the door an inch or two and watch the hinges as you lift the end of the door. You'll likely find the bottom hinge if flexing a lot, which indicates it has broken the welds that mount it inside the door.
In my case, I took the door off and took it to a shop to weld it back on. I did all of the grunt work, including cutting open a larger hole around the hinge plate and cleaning off the paint so the welder could get better access. The welder had it done in about 2 minutes and wouldn't take any money for the job.
