Tires and Sizes
I'm running 18x10's on the rear with a 65 offset with no issues. Tires are 285/30-18 Michelin PS2's - a little shorter than your 35 aspect Hankooks as I wanted to stay as close as possible to the 25" overall diameter of the stock tire size.
10 or 15mm spacers on the rear and you should be fine.
I like my 10x18 Carrera IIIs which are ET58 and are near the fender lip with a 265 tire and a 275 should fit easy as well.
Check out this calculator. It works well.
http://www.s4play.com/Tire-Wheel%20C...Calculator.htm
I plan to try my 18" Kinesis wheels from my '85 928 on my 968 Cab(if it ever gets here!). They have 255s & 295s on them & I believe they are 9's & 11's. Don't know the ETs but they were ordered specifically for a 928 by 928 Specialists for one of their cars. I did have to slightly flare the rear of my car for them to fit, which I won't do on the 968 if needed.
