New front zimmerman cross drilled sqeeeeeking
Hi, I just put some new zimmerman cross drilled up front and they are sqeeking like carzy... I've put some jurid new pads also...
Did I install them wrong or is there anything I can do to stop it???
thanks
thanks
Unfortunately, to install these stickies, you have to remove the calipers. Typically, you can swap the discs from up top if you are not using these anti-squeal pads. Installing them should help the pads from moving around in the caliper.
