968 Forum 1992-1995
HELP ADVICE BIG RED BRAKE'S
Old 05-14-2011, 08:45 PM
Jay Wellwood
Jay Wellwood's Avatar
Just something I'm thinking about Raj.
I looked up the cost of the Big Reds from the 928 GTS for a direct application. Calipers and cross drilled rotors are quoted at ~$1300 for the full set. Seems like a pretty good deal all things considered unless someone has a better line on these?
Also...looking for info on the exact placement of the NACA ducts on the hood.
Old 05-15-2011, 05:12 AM
FRporscheman
FRporscheman's Avatar
I have a set of 996tt monoblocks with drilled rotors, hardware, even a large spare, that I would sell for less than $1300. Extremely low miles on the set, almost new. Send me a PM, it's 1am and I'm going to bed.
Old 05-15-2011, 08:39 PM
User 41221
User 41221's Avatar
Don't forget to add in the adapters if you are running a non M030 set up.
Old 05-15-2011, 09:37 PM
Jay Wellwood
What is, if any, the difference between the 996 and 928 calipers?
Thanks for the info - still just fishing for info.
Old 05-15-2011, 09:38 PM
Jay Wellwood
Adapters...another item apparently.
Still learning (is it that obvious?).
Old 05-16-2011, 12:59 AM
FRporscheman
Well I'm no expert, so you should double-check everything I say, but from what I've gathered the "big reds" and "big blacks" are the same caliper, and the black ones came on the 928 GTS, and the famous big reds came on the 993tt. The 928 S4 and 968 m030 use a slightly smaller caliper, which was also black. The stock 993 uses a caliper slightly smaller than the 928 S4 and 968 m030. The stock 968, 951, 964, etc uses an even smaller caliper, which I think people call the "baby blacks", which is funny because they might be small in Porsche standards, but they are not small generally speaking.
For fitment on a 968, any caliper except for stock will require an adapter (and it's the same adapter for all of those other calipers). I think the adapters run about $250-300. You will also need new rotors and pads, and possibly wheels. I think the stock brake lines work.
996 monobloc calipers (which is what I have) are smaller than big reds in size but they provide comparable braking power, and weigh a lot less. They are 1 solid piece of aluminum (as opposed to two halves bolted together) which is a big plus. Anyway I'm sure I missed something or got something wrong so someone please correct me.
Old 05-16-2011, 05:49 AM
Vilhuer
Vilhuer's Avatar
Also 964 T3.6 but not 964 T3.3.
Big black/red caliper is only slightly bigger. Real difference is pad height. Annulus is 51mm vs 60mm IIRR meaning contact area is much bigger.
Old 05-16-2011, 04:10 PM
FRporscheman
Thanks for the info Erkka.
Old 05-16-2011, 04:26 PM
Damian in NJ
Damian in NJ's Avatar
Originally Posted by Jay Wellwood
Thanks for the info Damian.
I don't recall the 968 offset off the top of my head. Do you happen to recall the offset the wheels you now have came with?
Again - thanks for the information. I'm leaning to this as a future mod to my project (somehow being able to go faster requires being able to stop faster too!).
The kit came with adaptors and whatever other hardware that was needed; I can't remember where I bought it!
And I don't recall the offsets on the Supercups either, sorry.
Old 05-16-2011, 09:55 PM
RajDatta
RajDatta's Avatar
I actually have a set of brand new adapters in case someone is looking. At one point I had bought big blacks and adapters for the cab, then I realized it only makes 236hp and gave up on the additional weight from big reds, rotors and the additional rotating mass.
I returned the calipers but still have the adapters.
Quick Reply: HELP ADVICE BIG RED BRAKE'S
