968 Forum 1992-1995
Sponsored by: HBI Auto
dash light upgrade
Old Apr 17, 2011 | 07:48 PM
mikew968's Avatar
mikew968
Default dash light upgrade
So, does anyone have a good diy for replacing/upgrading the dash lights. Also, do you have to remove the steering wheel/airbag?
Old Apr 17, 2011 | 11:24 PM
ramius665's Avatar
ramius665
I haven't replaced/upgraded the lights in our 968, but I've done it on our 951. BLUF: re-covering the factory reflectors is the best thing you can do. I purchased the Jager Engineering LED kit and it worked great... for about 2 months. Then the LEDs would die from the vibration. I went through two kits before I just gave up and went back to stock. I have removed the cluster with the wheel still in and also with it removed. It's a MUCH easier job with the wheel removed and you won't have to contort your hands to get to the connectors that way. Good luck and if you have any questions, PM me.
Old Apr 18, 2011 | 12:17 AM
odurandina's Avatar
odurandina
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
if you do a search there are probably well over a dozen threads on the 944 forum.
i chose to front-lit my instruments. and everything looks pretty good/spectacular now.
Old Apr 19, 2011 | 04:57 PM
Grandpa#3's Avatar
Grandpa#3
From: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
Hi Mike, Check out the link below on how to make the instrument lights brighter. Disconnect the battery negative wire and wait 20 - 30 min. for the Air Bag Compasitor (sp) to discharge if you are pulling the steering wheel.
http://www.texasblake.com/porsche/te...orhousing.html
http://forums.pelicanparts.com/porsc...light-fix.html
Cheers,
Larry
Old Apr 23, 2011 | 01:38 AM
blue44's Avatar
blue44
did mine this morning - removing the airbag was easy with a torx t-30 bit ( disconnected the battery the night before ) and no problem sliding the instrument cluster out with the wheel off. Also removed the plastic cover that hides the rotating contact. I found it was only necessary to disconnect the left side of the cluster and turn it out to access the bulbs, these connectors are pretty stiff ( and delicate ). I find the lighting adequate without updating the reflectors, but you wouldn't call it bright. One funny thing, you can't power anything up to test your work ( or your parts ), if you do, you'll need to reset the airbag light...
Donn
Old May 4, 2011 | 03:21 AM
phil0618's Avatar
phil0618
Check Clark's Garage for a very complete write up on this and which bulbs to buy etc. I did the upgrade and it's very nice. Not a huge difference, but it's now the way it should have come from the factory.
Old May 5, 2011 | 12:01 AM
potent951turbo's Avatar
potent951turbo
iPod Tamer
944online.com also sells a kit to restore the reflectors, and also has LED's to replace the stock cluster lights. I haven't tried it personally but have run across it on their site numerous times.
