Turbo RS Centrelock Hubs
The mounting of the calipers is different on the M030 spindels ,you could use adapters to get the original calipers to fit but i think it would be easier and better to get the big calipers.
Mark, some interesting projects you undertake!
I have spoke to Paul a couple of times sometime in the past, pleasant bloke. Also quite sure i had a good look around 'Bubbles' at Silverstone, unfortunately on the back of a low loader possibly from a small problem and no spares. Might even have some photos somewhere.
JP
p.s. i'm based in Cheshire also.
JP
I actually have seen your car on the street on a few occasions – looks fantastic and well shorted. I’m in Wilmslow, Cheshire
For all four corners you'd need...........
Hmmm looks like D9 would do well to produce/sell a whole kit...yes?
@Mark&Beni
Are you planning to make this as a kit ,and if so when do you think this would be ready ? what would be the cost of such a kit?
Something else I just thought of: When replacing stock 968 spindles with M030, is it necessary to upgrade to 968 M030 brake calipers and rotors as well?
Best regards,
Mark
