WTB MO30 Front Sway Bar
Hardly anyone ever sells them. They are a very popular upgrade. You are better off buying a new set from sunset porsche for close to $500 for everything (front and rear).
Regards.
Regards.
I can get you a brand new M030 front sway bars for $275, if you need the rear M030 sway bar, it's $150.00, both are plus shipping. The front sway bar bushings are $10 each.
I can look up the rest of the hardware in a bit, if you are interested.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
they're out there, lurking.
love it when sponsors come out with the great news... can somebody seriously explain the benefits of adding the weight of a heavy swaybar to the front of an already hp/weight challenged car ? is it really that great for the street ?
Depends on how you drive, but yeah, I think its worth it. You can definitely feel it if you put the car into a corner.
Lyndsey Racing sells them. You can buy the complete set front & rear including bushings for less the $500. Even cheaper if you combine the M030 Front with the LR Rear....which is identical to the M030 rea, only it has 5 adjustments rather then 3 and costs less. I have the set on my car and it made a huge difference when compared to stock.
I am a little confused, is the M030 hollow or are you refering to the Tarret brand. Also does anyone know the weight comparison for the front bar?
I currently run the Weltmeister setup on my race car and it weighs approx 30lbs with all the hardware. The MO30 setup is hollow and way lighter.
GB
GB
