968 Forum 1992-1995
968 cam chain timing
Old 09-20-2010 | 11:52 AM
rgs944's Avatar
rgs944
Default 968 cam chain timing
A post on another thread got my attention and was just wondering if the cam chain timing is something that needs to be set periodically or just when wrenched on?
Old 09-20-2010 | 12:18 PM
RajDatta's Avatar
RajDatta
You can't adjust the chain timing, but you can adjust the exhaust cam timing in relation to the crank.
The chain is preset at 7 links? (if I remember correctly) between the two cams.
Raj
Old 09-20-2010 | 02:48 PM
rgs944's Avatar
rgs944
How often should it be checked or adjusted? I have around 120,000 miles and did not see anything in the maintenance records about it. I plan to do the belts, waterpump and variocam pads this winter.
Old 09-20-2010 | 03:56 PM
968rz's Avatar
968rz
If you don't know when the timing belt and such was replaced, the general rule is do ASAP then every 5 years or 30-50,000 miles.
Does that sound right to the rest of you guys?
Old 09-20-2010 | 04:05 PM
Lemming's Avatar
Lemming
You might as well do the chain when you do the cam pads. Also, check the teeth on both sprockets, they are known to break.
Old 09-20-2010 | 07:05 PM
ernie9468's Avatar
ernie9468
Talking
+1 120,000k miles is a little long without checking the tensioner/pads &chaine if the pads let go you can kisse your head goodby so do it ASP,__FRporscheman (Arash) has a very good DIY write up for doing the job not only does it show how to do it but give you all the parts needed to it properly.(Broken teeth on camshaft sprocket)
Quick Reply: 968 cam chain timing
