Why a foam hood pad set??
http://www.jageng.com/garage9/produc...roducts_id=444
Found this, with 'forum' creds attached.
I like jageng, as you can see from the product shot of mine they use all over their site. But I'm wondering: what does this do except possibly accelerate rusting? Quieter engine, I guess...
I had to replace a 944 hood pad set once, because it had rotted out.
Some times I think those 'forum' boys just need a new thing to buy every couple of weeks.
Porsche removed this from their hoods because this was acting as insultaion and keeping the engine temps too hot. They had a reason to get rid of it. You could see how the hoods of 951's would get oxidized from high temps and as you said, the foam would just crumble over time.
I would stay away.
Raj
I would stay away.
Raj
I put some insulation on my hood predominantly to see if it would quiet things down and while it may have had some positive effect on noise I'm thinking of removing it because as Raj says I'm convinced my engine runs hotter.
I would stay away.
Raj
I would stay away.
Raj
I do not think it makes the engine temperature any higher than running without. If anything, it helps prevent the factory hood paint from fading. Also, the finish on repainted hoods tends to crack without the insulation.
I have replaced it with new insulation from Porsche in my 1991 Turbo.
None of all post-88 cars I have seen had that POS hood foam, including a respectable number of turbo cabs.
IIRC your turbo cab is Swiss spec though and cars for the Swiss market had all sort of nonesense added for pollution/noise, such as plastic gearbox casing and additionnal air box on S2s. Perhaps the hood foam was also part of it.
Errrr... Not really.
That's good to know. Thanks for clarifying. Tommye's 51 cab is also Swiss and has the insulation. The plastic gearbox casing was a Swiss 944S2 thing. The Turbo case is bare.
However, POS or not, the fact remains that the hood finish fades without the insulation. Both my cabs have factory paint and the S2 is considerably more faded, in spite of being a lower temperature engine. The Turbo would probably be matte by now without the insulation.
Raj
I don't follow. You said earlier that U.S. 944 Turbo S cars came without hood insulation. Did you buy new pads and install them on your car? If so, was your 951 new when you fitted the pads? Otherwise, the heat had most likely already affected the hood finish. Especially on a red Turbo.
Raj
