968 Forum 1992-1995
Sponsored by: HBI Auto
968 air box mod
Old Feb 14, 2010 | 04:49 PM
rgs944's Avatar
rgs944
Default 968 air box mod
I have read most of what has been written on the air box in the search forum but was not able to download the instructions. It seems pretty straight forward. It sounds like four 2in. holes drilled with a hole saw in the front of the box. I assume that two holes go on one side of the snorkel and 2 holes on the other side. Is that right? Any pics would be great. Also at what level should they need to be drilled, towards the bottom of airbox or is just anything below the filter OK. I have the cover to hide them so I probably will not be finishing them with the speaker trim. I know there is some discussion as to how much this mod helps, but even the critics agree that it does do something and I do like more of a hotrod sound. I just don't want to start a new debate on the merits of doing it. Any help would be appreciated.
Old Feb 14, 2010 | 06:17 PM
mikew968's Avatar
mikew968
I believe you just center the holes and even them out.
Old Feb 14, 2010 | 06:56 PM
ernie9468's Avatar
ernie9468
This is how PorscheDude1 did his on the Polar Silver maybe he could give you the holes size & more infos .the holes seem lot bigger then 2" to me.
Old Feb 14, 2010 | 07:08 PM
ernie9468's Avatar
ernie9468
This is another way to do it but myself I don't really care for it .
Old Feb 14, 2010 | 07:28 PM
rdhayward's Avatar
rdhayward
I've been very happy with the mod I did:
https://rennlist.com/forums/968-foru...rt-deux-2.html
Still haven't made the 2nd cutout or the pretty ductwork described later in that thread, but I like what I did to the airbox better than the 4x2" holes in the other setup.
Old Feb 14, 2010 | 07:43 PM
rgs944's Avatar
rgs944
Thank you guys. It sounds like the most important thing is to just get some extra air in there above what the snorkel can provide. My hood is candidate for a respay in the next few years. I wonder about the possibilities of adding some Turbo look a like air vents to supply some cool air. I know that it probably gets plenty of cool air from the front but I do love the looks of those hood vents.
Old Feb 15, 2010 | 10:57 AM
John Etnier's Avatar
John Etnier
This is the documentation for the original mod. The accompanying article said they'd found no further gains with larger openings than these. With the 'ports' attached, noise is controlled as best it can be.
Old Feb 15, 2010 | 01:02 PM
rgs944's Avatar
rgs944
Thank you John, I was able to download the pdf and that tells me everything I need to know.
Old Feb 16, 2010 | 08:20 AM
Eric_Oz_S2's Avatar
Eric_Oz_S2
So what does it add (apart from induction noise) to hp and has it been verified?
Old Feb 16, 2010 | 11:06 AM
richard glickel.'s Avatar
richard glickel.
It works. Easily the least expensive 3-4 additional h.p. you can obtain for the 968.
Old Feb 16, 2010 | 12:22 PM
John Etnier
The magazine article from the time the mod was documented claimed more than that:
The results were amazing. The Airbox mod and K&N air cleaner together gave us 10.8 peak horsepower and 7.3 lb/ft of peak torque for about $40!!!
Old Feb 16, 2010 | 01:02 PM
richard glickel.
We certainly didn't realize anything like that on my 968 racecar. 3-4 h.p. gain on the dyno "before & after". Still, for a couple of holes (4 to be exact) and rubber finishing rings, I was happy to see ANY gain. As the standard disclaimer goes, I suppose "your results at home may vary".
Old Feb 16, 2010 | 07:14 PM
John Etnier
Yeah, well: Flash in the pan, right?
Old Feb 16, 2010 | 08:03 PM
Damian in NJ's Avatar
Damian in NJ
Did you have any other gains from cat/exhaust/headwork that may have already gained you some extra hp?
Old Feb 16, 2010 | 09:00 PM
mikey_audiogeek's Avatar
mikey_audiogeek
Doesn't it do away with the ram air charging, since the airbox is now "vented"? I wonder at what speed the effects are negated?
