Clutch vibration
Clutch vibration
My '94 has developed a vibration in the clutch when depressed. It has been suggested that it is caused by a mis-aligned release bearing and is "no big deal". Anyone have a similar experience? What did you discover is the cause? Is it something that needs repaired "now"?
Sounds more likely to be a bad relaese bearing than a pilot bearing. If the bearing becomes worn and devlopes play it will wobble when you put a load on it, by depressing the clutch pedal. That would cause a vibration.
