Help: S2 with 968 engine transplant - Tach not working
Anyone have any suggestions on where/what to look for? It has even sort of stumped my mech.
Chad
Chad
Check the wire coming off of the DME to the connector at the back of the dash. If there is continuity try checking it with a scope to see if you pick up a signal. If you don't have a signal, then check to see if there are any hall sender codes or anything like that.
+1 To 968workaholic,
The tachymeter signal goes via the DME connector in passanger footwell and as you need to modify that to supply +12V to pin #7 for 968 DME on S2 you might've a loose connection OR broken wire.
