Front bumper cover
Front bumper cover
I bought the car without engine and the undertray was missing. The right fog/driving light lens is cracked and the cover has a 4 cm tear in the right front and the right inner fender has been in contact with the wheel. I can tell because it worn away completely beside the access panel to the light bulb. When I removed the front cover I noticed the right side attachment bracket is bent quite a bit. I'm guessing there was a collision that caused the something to wedge under the front corner causing the inner lining to push back on to the tire.
My question is: What fits under the leading edge of front cover? Does anyone have a pic of the front underside?
On the Radar
It is called a "bat wing" on the forums.
You can get a new one from sunset imports for $375 or so.
Be sure to order all the hardware for mounting as well.
You could also try the following for bumper cover, fog light and fender approns:
DC automotive
Oaklahoma Forgien
DC automotive
Oaklahoma Forgien
Jim- I do not have a pic but this might be better. "batwing" nick name most call it but it is called an undertray in the dwg.. This should put the pieces together for you- Cheers, Mike
