Power Steering "Double ended" bolt
Anyone have one laying around?
No PET books seem to have what the 968 uses. I ordered what I thought was correct and ended up with a regular 13mm bolt. I have the spacers but the strange bolt is allusive.
BTW, mine apparently broke at some point. I was checking things before our DE and discovered the back portion was broken off.
It's the same as on a 944. I just checked PET and this bolt is not pictured with the PS pump nor with the lower BS cover (aka PS pump bracket). Sorry but I don't know the part number for this bolt but I know what you're talking about.
After further inspection, Raj is right. The bolt that broke is actually part of the pump. The bolt broke off inside the pump housing. I'm affraid I will need a new/rebuilt pump.
Any recommendations?
