front sway bar preload
Any ideas on how to remove preload from the stock sway bar set up on a 944/968? I'm using a 30mm stock bar with stock bushings and mounts.
Thanks in advance.
Thanks in advance.
Steve,
I realize there isn't adjustability in the stock links...my question should have been phrased better...
Does anyone know of adjustable links for the stock sway bar?
Gene
Gene
I have the fully adjustable Weltmeister sways bars on my 968 Cab. I may consider swapping them to the race car and putting the Porsche sways on the 968.
If you want a new adjustable sway bar, I recommend the Racer's Edge product.
http://www.racersedge-inc.com/racers...open&id=12.3.4
Otherwise just get the m030 30mm sway, which is more than enough for most street legal applications.
