Headlight Conversion
I did a fixed headlight conversion on my car, using Hella Bi-halogens. Here's a picture of the finished result:
Attachment 824076
I attached the Hella's to the bulkhead via some brackets that I made, constructed two-piece buckets from aluminum flashing, made custom-shaped aluminum brackets to attach the buckets to the fender, and yes, I even made my own curved lexan covers. But I have to tell you, it is a very time-consuming, tedious, and at times very frustrating project, unless you have the patience of a monk. There's no template to work from so it's a lot of custom fabrication, which means a lot of trial and error. And in my case, lots and lots of error. Here are some pictures of the project as it went along:
Attachment 824077
Headlight mounted to the bulk head
Attachment 824078
Lower half on bucket in place
Attachment 824079
A few of the bucket-mounting brackets
Attachment 824080
Rear and lower bucket pieces in place
Attachment 824081
Close-up of a curved lexan cover
The lexan cover creation was quite an adventure. I'm not sure how many pictures Rennlist allows per post, so I'm going to show how I made then in a separate post below.
Attachment 824076
Attachment 824077
Attachment 824078
Attachment 824079
Attachment 824080
Attachment 824081
OK, to create the curved lexan covers, here's what I did: I fist obtained a couple of pieces of scrap 1/8" thick lexan from the machine shop at work. I had one of the machinists cut them into rectangles a few inches on a side larger than the final size of the covers. I cut templates for the covers out of cardboard, and created the following contraption, in which I very carefully cut an oval in a piece of 1/4" MDF exactly 1/4" larger than the template:
Attachment 824082
Frame on which the lexan rested during the heating process
The idea was to place the lexan on this frame, place a curved weight in the center, place the assembly in the oven, and let the lexan sag until it reached the appropriate radius of curvature. Finding an appropriately shaped weight took awhile - it's amazing what a "flat" world we live in. But I finally settled on this piece of wooden staircase trim:
Attachment 824088
Weight I placed in the middle of the piece of lexan during the heating process
But I had a problem - how would I know when the piece had sagged enough to reach the target radius of curvature? I needed an endpoint detector, in other words. So, I attached a metal right-angle bracket to the weight, and attached a wire to the bracket. I attached another wire to an arm I attached to the frame, which you can see in the picture of the frame. I bought some insulating jacket material to place over the wires, which I ran out of the oven, and attached to the leads of an ohmmeter. I strategically set the distance from the bracket on the weight to the screw connecting the wire to the arm to match the desired radius of curvature. I then VERY CAREFULLY placed the whole assembly in the oven, and placed an additional metal weight to the top of the wooded weight. This was pretty dicey, as there was a high risk of the weights tipping over. I then heated the oven to something like 275 degrees, and waited until the lexan sagged enough for the metal pieces to complete the circuit, and trigger the ohmmeter. Then, I traced the cardboard template onto the now-curved lexan, cut it to size with a manual saw (I was afraid a jigsaw would be too risky), and sanded the edges to give them a smooth appearance, and get the pieces to their final size.
Then, all that was left was fabricating the small mounting brackets for the covers, drilling the holes in the fender for the brackets, painting the brackets and screws black, and attaching them to the car. I've very pleased with the end result. However, I think the weight savings is well under 50 pounds. I sold my original headlight assemblies, and the entire box with all the parts weight 38 pounds. Still a substantial savings, but well shy of 50 lbs.
As far as the aesthetics of it, I think for a "light-in-a-hole" approach, it looks OK, but I do think it kind of ruins the aesthetics of the 968. I did it strictly to save weight, as my car is a mostly-dedicated track car. Also, the quality of the light sucks - far worse than stock. With the high beams on, the bi-halogen light throw off about as much light as the stock headlights in low beam mode.
So would I recommend doing this? Only for a track car. I've never indexed a set of torsion bars, but from what I've read, I would say this conversion was at least as difficult. Would I do it for anyone else? Sure - assuming a wage of about $3.00/hr, I think $10K would be about right
Attachment 824082
Attachment 824088
http://www.aerocatch.com/
Some nice black ones would just disappear on the big beautiful black hood and look so much nicer.
Cheers
Mikey
Cheers
Mikey
Thanks, guys, and thanks, Mikey, for the tip on the HID bulbs. As long as it's plug-and-play, and I don't have to EVER take the assembly apart ever again, lol! It's amazing how crappy the bulbs that came with the Hella's are, so it's good to know there's an alternative.
http://retro-solutions.net/product-l...pg1-cid86.html
Cheers
Mikey .
